Question about Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Posted by nedder5 on
Kevin Doyle
  • 3 Answers
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously when turned on.
Posted on Nov 16, 2018
Dan Webster
  • Patton Electric Master
  • 8,220 Answers
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 21, 2010
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I need two more rubber pegs for the base of my Patton heater. It only came with two. How can I get 2 more?
Almost every manufacturer will supply free parts for new equipment that is missing them.
Call them and let them know and I'm sure they will mail them to you.
Gary
Jan 23, 2011 | Patton Electric Patton PUH680-U Electric...
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
Jan 05, 2008 | Patton Electric Patton PUH680-U Electric...
Operator's Manual Online?? Patton heater model# POH2501
I have a manual and would be happy to upload a copy to you. I haven't found a Patton website yet. I'm ultimately hoping to find a place where I can buy replacement wheels for my Patton POH2501, but so far, no luck.
Let me know if you're still in need of the manual.
Nov 07, 2007 | Patton POH2520-U Oil Filled Radiator...
Patton Electric Patton PUH680-U Electric Utility Heater 1500-Watt Logo
787 people viewed this question
Top Patton Electric Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
