Question about Canon PIXMA MP530 All-In-One InkJet Printer
Error 5110 for Canon MP530. Can I fix? - Canon PIXMA MP530 All-In-One InkJet Printer
Posted by lexcodex on
Troy Staley
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
Or it could simply have some ink on the data strip behind the printhead and that makes the carriage not know when to stop. if it makes a noise from the motor that positions the carriage jumping teeth in the belt that could be it.
Posted on Nov 13, 2017
abhilash subramanian
    New Friend:
  • 105 Answers
Sounds like a carriage issue and unfortunately you can buy that printer new for less then it costs to get a new carriage put in
Posted on Sep 21, 2010
4 Related Answers
Anonymous
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
welfy
SOURCE: Canon Pixma MP600r - error code 5110
i took the printer into a service center and they have replaced the board and the paper feed. seems to be common
thank god its still under warranty!!
Posted on Jun 15, 2008
Anonymous
  • 90 Answers
SOURCE: please show me step by step to fix error 5110 in
This is a carriage error.
1. Printhead is stuck to the docking area either because some old ink has become like glue.
2. A piece of paper got over there and is jamming it.
3. The spring is weak and is not pulling the docking area down.
4. The Purge unit has failed and needs to be replaced.
Turn the printer off and then slide the printhead to the left and use a flashlight to see if you see any paper stuck around where the two sponges that where sitting below the prinhead or if it just didn’t lower like it should have.
Posted on Oct 03, 2009
bhadresh khatri
  • 191 Answers
SOURCE: 5110 error
please your printer in catrideg is check and moment to hand's and softly is runing to do check. and your pc in old printer progremmes is un instoll and restart pc and re instoll in printer progremmes and printer driver and you go to the start menu select and aply add new printer select and chouse the printer company and printer number select and aply ok and start the printer and aply paper print check. ok.
How do i fix error code 5110 on the canon iP4200
According to the following link, it pertains to the carriage lift mechanism. Perhaps something has gotten jammed or its not seated properly. Canon iP4200 PIXMA Photo Printer Service Manual Page 13
May 29, 2014 | Canon PIXMA MP530 All-In-One InkJet...
I can't locate my manual for the mp530. I have an 'error code 5110"
Error code 5110 means something is wrong with the carriage for the cartridges. Try re-seating the cartridges to see if the error goes away, as well as checking if anything is blocking the carriage from moving. If not, it's very costly repair and you're better off buying a new printer.
Mar 29, 2011 | Office Equipment & Supplies
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Alarm button on printer and a error code of 5110
Hi there
Click on the link to download it.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
May 06, 2010 | Canon PIXMA® MP530 All-In-One Printer
5110 error
Oct 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Please show me step by step to fix error 5110 in canon MP530 printer!the alarm keeps flashing and i need to print several important documents right now.please give me the best information so i can fix my...
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon mp530 getting error message 6a00
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,954 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
