Question about Technics SL-BD22 Turntable
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running fast (on the few occasions it is not going slow/fast) Is it a dud?
Posted by vinylshrine on
Grubhead
  • Technics Master
  • 5,700 Answers
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Posted on Sep 21, 2010
Pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
Jun 15, 2012 | Panasonic Technics SL-1200MK2 Turntable
Our Technics SL-1200MK2 has issues with the direct drive. It does not spin at a constant speed. When stopped, it does not stop immediately. What can be done to solve this?
To adjust stopping speed you'll have to remove the plate by pulling it up. Then there is a plastic cover that has some screws, remove the screws and remove the plastic cover, you'll find a variable resistor that reads something like brake. Adjust it to the left or to the right with a screwdriver and see at which position works best.
To solve the constant speed problem you'll have to replace the pitch regulator.
Go to any panasonic/technics service and buy the pitch. If you have a bit of soldering skills you'll be able to replace it by yourself. You can access the pitch regulator unscrewing all the screws under the device and then removing the cover.
Hope you can solve the problem!
May 18, 2011 | Technics SL-1200MK2 Turntable
I have a technics sl-b2 that hasn't been used in a while. It was my fathers, looks in good shape. I put a new belt on. I'm having trouble with the pitch adj. It seems to not be able to maintain the same...
Switches and other controls that permit the user to adjust the speed on the turntable often become erratic due to oxidation of the metal contacts contained therein. Dust and smoke add to the problem. Cleaning the controls with quality electronics-type contact cleaners usually gives years of happy service. The job is best left to someone familiar with the complete assembly since other finite adjustment potentiometers are often employed and located on the internal circuit board.
Aug 06, 2010 | Technics Audio Players & Recorders
One of my technics' 1200 turntable's tone gets too high
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Hope this helps some.
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Repair
Aug 27, 2009 | Technics SL-1200MK2 Turntable
Cannot adjust speed on a vintage Technics SL-B30 Turntable
First has anybody tried to repair it before you got it Gerry? I ask this because someone could have fitted the wrong type motor!
If nobody has done anything to it, I would take a look at that servo control board. Is there any IC's on it, if there is look at them with suspicion.
Aug 25, 2009 | Technics SL-1210 Turntable
Platter problem
THE PITCH slider or the variable resistor could have gone faulty. A new pitch is only $25 i think. They may need to salvage the pcb from your old one as technics no longer manufacters them. I've never seen the pitch led stay on lock when the actual pitch is not at zero. Hopefully the pitch did not short out the brake or the variable resistors on the motor's circuitboard.
keep me poted.
Oct 25, 2007 | Technics SL-1210 Turntable
Technics problems
There is no drive belt on this unit. This is a direct drive turntable. Your pitch control might be on it's way out. Are you getting any sort of unusual speed issues? Or is it just sort of running slower than usual? There is a pot you can adjust under the turntable platter to speed it up a bit, however, this is only a temporary fix. It is listed as VR301 - and is on the main board under the turntable platter - it says PITCH on it. Try adjusting that pot, to see if it does anything. WORD OF CAUTION: Make sure your turntable platter is ALWAYS on whenever you power up your turntable, and if you do any electrical modifications, make sure you always disconnect your turntable from it's power source to be on the safe side. If this does not work, then either your pitch control (which is a variable resistor) will need to be replaced. The problem could also be one of the drive components on the main board, however, this will need to be worked on by a service tech. Hope this helps. - Justin
Jun 11, 2007 | Technics SL-1200MK2 Turntable
Technics SL-BD22 Turntable Logo
673 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
