This model does not have a tuner so you will not be able to record off of tv unless you run your cable box or dish satellite's audio and video outputs through the dvd recorder's front or back inputs(L1 or L2) and record from those sources. Even then the cable box or satellite box would have to be tuned to the channel that you want to record. If you choose to do this you must go to your on screen menu and under setup/general settings/video/video input you will need to select the video input source(L1,rear or L2, front).
I cannot record vhs to dvd it say on one vsh record prohibited
You need a cable box as your unit does not have a built in tuner.good luck.
