Microwave Ovens Logo
Posted on Sep 21, 2010
Model lmc1543ss. Handle snapped and broke can I get a new one
Lisa Hascal
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 24, 2014
Lisa Hascal
Contributor
Level 1:
Answers
Questions
0
Helped
283
Points
0
Jus wondering if you had any luck finding this handle? We need one too.
LG Microwave model LMC1543SS door won't open anymore it seems locked
take cover off there are plastic catches who could have wear and tare
Door handle broke off
bru the front internal cover snaps off. you need to stick a screw driver in the edges and pry it apart being very careful to not snap it or bend the outta metal frame undo the handles screws and replace as before but in reverse
good luck
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
1helpful
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Handle broke off on Samsung 7185STG. I ordered a new handle from Samsung parts and need instruction on how to replace.
remove the inner panel on the door itself and with the use of a Flathead screwdriver carefully pry off starting closest to the door hinge and careful not to break off the tabs push them down one by one until you free the top and remove all together now then 2 screws or nuts are accessible simply remove and replace .set the bottom of the trim panel in place then snap the upper portion back into place ..you are done
11helpful
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
repairclinic.com
The handle broke, got a new one took off the
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Sometimes you have to rotate the handle after the top screw is out.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If this doesn't solve your problem, please reply back with your brand and model number so we can help you.
3helpful
Our handle broke off our GE Profile Spacemaker Oven
You can easily perform this repair on your own and save the cost of labor charges and a service fee. Go to appliancepartspros.com and type in the model number you provided. The door handle is located under Section 1 as item number 1801. Make sure you order the correct color.
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
