I will not further review this camera since many have given fine reviews
here. My goal of this review is to explain a fix to a problem I had
with this camera. Upon a search, I learned that others had similar
problems but could not locate a good answer or fix.
THE PROBLEM: Casio Exilim EX-Z90 turns off suddenly after being
turned on AND/OR the camera will NOT stay on after the power is pressed.
THE FIX: I was completely at a loss for this problem. I searched
Casio's site, I e-mailed their customer service, and searched the
internet for a fix and found NO HELP. One day my child told me that if
they pressed against the bottom of the battery enclosure that the camera
stayed on. I began to explore what this could mean. It was soon obvious
to me that the three copper nubs that the battery sets against in the
camera must have been pressed down too far. My child had a difficult
battery one day and pressed very hard to get it out. This must have
depressed the copper connectors (nubs) to where they did not make good
contact with the battery causing the momentary power up and then quick
shut down.
I had a pair of tweezers that allowed me to gently pull the copper
connectors back up slightly thus allowing the battery to have proper
contact. Once this was accomplished, the camera powered up and stayed on
with no issues. You must be careful so as not to break the copper
connectors off because if you do, the camera is done.
Why Casio does not have this printed as a troubleshooting option is beyond me. I hope this helps others out there.
Good luck!!
The lens mechanism could be jammed and cause a failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre., being an expensive camera
get estimate before you decide. It will be good to have it checked at the Casio service as you do not have to run around for spares.
