Mu nokia 6070 is not work! when i turn on button on lcd display is light grey/blue screen and nothing ,no logo no clock no i can call! when i turn off button display not want to off ,continues to light grey/blue! i change display but same! what to do help please
when i turn on the button, the LCD will only will light, but there's no display. how can i fix it? please help.when i turn on the button, the LCD will only will light, but there's no display.
You can't post conmments that contain an email address.
Possible there is damage on the main board and could be cracked. So my advice is to get this checked at the Nokia care to get and estimate if you are not able to open and look for visible damage that can be soldered.
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code.
Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
1. Turn on the TomTom unit.
2. Tap the screen to bring up the menu.
3. Tap the "Change Preferences" icon
4. Keep hitting the arrow to go to the next page. Clock setting is on page 6 of the preferences dialog.
5. If the Set Clock option is greyed out, you will need to perform a system reset and then perform these steps over again.
To reset the system, start with the power off. Then, hold down the power button for about 15 seconds, until you see the TomTom logo appear on the display. When the logo appears, release the power button. After this reset, you should be able to turn the unit back on and proceed with your setup from scratch.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
its a high voltage on the responsible chip of display maybe u need to service that phone cuz u cant afford buying a LCD just for testing that is not a deal with LCD.
The dislpay driver IC inside ur mobile might have blown. So get into any authorised service center and get it replaced. Or it should be problem in Display.
