I think your goal with the 2 way switch is to be able to turn the landing light on/off from either the top of the steps or the bottom of the steps. When you run a one way light in with that circuit it will not make a complete circuit, hence the 2 way will not work. If your bathroom switch was in with the light switch at the top of the steps, you will have to seperate these two switches. Make the bathroom a switch by itself, and then connect the two way switches. If a circuit is not making a loop it will not work. 2 ways must make an uninterrupted loop, (the one way is interrupting the loop) in order to function properly. Hope this helps!!!
