Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
