Field and Stream F25SLUMI Wrist Watch Logo
Posted on Sep 20, 2010
HOW DO YOU OPEN THE WATCH INCASEMENT TO LOCATE THE BATTERY
I have a mk 5055 Michael Kors watch and I don't have the proper tools with me I only have a flat bed screw driver and I need to change the battery
Read the solutions given below when you want to change the battery right from your place.
step 1: Remove the back panel of your watch.
Step 2: Locate the battery in the holder and identify its type.
Step 3: Use the user manual for reference before installation.
Step 4: Place the watch and the back panel in a plastic bag to avoid contamination during replacement.
Step 5: Remove the old battery from the watch.
Step 6: Have in hand a newly purchased battery and install it.
Step 7: Check whether the watch works after installing.
Step 8: Replace the back panel on your watch.
Step 9: Set your time and wear it.
To Get Instant Support Call our Toll-Free 1-866-293-9220
How to remove oasis watch battery back
To remove the battery from the back of an Oasis watch, you will need a small flathead screwdriver or a coin.
  1. Locate the battery cover on the back of the watch. It is typically located at the 6 o'clock position.
  2. Insert the screwdriver or coin into the notch on the battery cover.
  3. Gently pry the battery cover off of the watch.
  4. Remove the battery from the watch.
  5. If you are replacing the battery, insert the new battery into the watch, making sure that it is oriented correctly.
  6. Replace the battery cover by aligning it with the watch and pressing it into place.
If you are having trouble removing the battery cover or if the watch has a different type of back, you may need to refer to the manufacturer's instructions or consult a professional watch repair service. It is important to handle the watch carefully to avoid damaging it.
How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
  • A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
    A cup or small box-This is to hold any screws.
  • How to change a Casio watch battery:
    1. Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
    2. If necessary, remove the watch band Removing the band gives you easier access to the back plate.
    3. Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
    4. Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
    5. Locate the battery It looks like a small metal button.
    6. Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
    7. Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
    8. Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
    9. Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
    10. Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
    Best regards. Jewel
    Need new watch back, by boyfriend ripped it up trying to get the battery door open
    Hello
    All you need to do is to try and get to a watch store and locate the type of wrist watch you need and go for it.Better still you could check it online before going to the store.
    BEST OF LUCK
    How do I reset thebattery on a casio ad-520?
    To reset the battery you need to locate the "AC" inside your watch. The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
    It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice. This will reset your watch an give you the ability to correctly wet your watch.
    Top Field and Stream Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Field and Stream Watch Expert? Answer questions, earn points and help others
