Question about Microwave Ovens
Hello I am not havingany problem.I need to activate ,my danby microwave warranty.
Posted by lornamuise on
Kelly
  • Microwave Ovens Master
  • 3,740 Answers
Go to this link:
https://www.danby.com/registration.php?ln=CE& (copy and paste)
If you have purchased an extended warranty you will need to go to this page to activate the extended warranty.
https://www.danby.com/warranty.php?ln=CE&tip=EXT
Thanks for choosing FixYa.
Kelly
Posted on Sep 20, 2010
I would like to Put my danby microwave warranty and registration
the to register --warranty details and equipment serial number will be on the warranty card that came with the equipment
follow those instructions
or
google the manufacturers site click on the " contact us" tab , fill out the details and in the comment box type in the equipment details , date of purchase , serial number , model etc and request that it be registered in the company warranty records
Dec 04, 2016 | Danby Microwave Ovens
None of the Microwave buttons on the panel seem to be working. I tried replugging it many times but to no avail. l am unable to start the microwave. How do I get the microwave panel working and start...
Could the Child Lock feature be active on the microwave? If it is active, there may be a "box" symbol formed by the LCDs in the display. Try pressing and holding the Stop/Clear button for 3 seconds (or a little more). You should hear a long beep and the clock should return to the display (if it was set).
I do not have the DMW1153. However, I assume the DMW1158 is similar. The manual for the DMW1158 is here: http://www.danby.ca/cms/uploads/products/en_manual/DMW1158BL_EFOM2_%28web%29.pdf . Additional Danby microwaves are listed here http://www.danby.com/products/cooking . If you go to any of the links, the manual will be available from the Literature tab.
I hope this helps.
Jun 10, 2011 | Danby DMW1153 Microwave Oven
I have the danby designer Mod DMW162W-ORT that won`t heat at all but everything else works. Hums a bit louder but will not warm.
The Magnetron in your unit is no longer resonating properly. The Magnetron produces the microwave frequencies and when it resonates properly, it will provide the excitation to heat your item(s). As well, the diode that accompanies the magnetron needs to be replaced as well. Should it be under warranty, take it back. Out of warranty? Have an appliance tech repair it (usually around $175) or get a new microwave.
This is typical for most microwaves. No such thing as quality any more.
Apr 12, 2011 | Danby Microwave Ovens
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
Beeps every 30 seconds
Your oven has a 24 month parts and labor warranty. I would contact Danby:
Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Or you may e-mail Danby Service at [email protected]
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Danby DMW119 Microwave Oven
BEEPING EVERY 30 SECONDS
Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
Registration
Try this link - it is the original site of DANBY. Not sure about the 2 yr warranty issue, but you can check with them at http://www.danby.com/contact_us.
It's always a good idea to check your spelling when you type in a web address. The correct web address is: http://www.danby.com
Jun 29, 2008 | Danby DMW1153 Microwave Oven
Microwave Ovens Logo
222 people viewed this question
Top Microwave Ovens Experts
Marvin
Marvin
acmservice
Are you a Microwave Oven Expert? Answer questions, earn points and help others
