PC life warning indicates that the photoconductor has nearly reached its expected life rating. You can still continue printing but will be at risk for developing print quality issues. It is advisable that pc unit be replaced. Now, when you replace the pc unit you will also need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Quite mode OFF is the default factory settings. To reduce noise produced by the printer, quite mode need to be turned ON. This will reduce the amount of noise but this will set the printer run at half speed.
To do this click on Menu Button > General settings> Quite Mode> ON and then press the check button to submit.
For further assistance, please contact Lexmark Technical Support.
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/oSJU64
sfsf
