Question about Health & Beauty
How to setup push mail for samsung monte phone on gmail
Posted by g8pratik on
Elviraramos
    New Friend:
[email protected] Samsungkeyboardsetup
Posted on Dec 04, 2015
Umang420
    New Friend:
I'm not sure if this is of any help
to anyone but these are the steps
I used to set up email on my
Monte. I'm using an old hotmail
account that didn't support IMAP
or SMTP properly.
1.Set Up a GMail account eg.
[email protected]
2.Set GMail to allow IMAP via the
settings link the the top right
hand corner. (under Forwarding
and POP/IMAP)
3.Under accounts and import set
up the send mail as to send mail as
[email protected] Set this
to default send adress
4.In the same tab under check
mail using pop3 set up the pop3 to
recieve from [email protected]
hotmail.co.uk
5.Under Email Accounts on the
Monte set up email with the
following charecteristics:
Account Name: Hotmail
SMTP Server: smtp.gmail.com
SMTP Port: 465
Secure Connection: SSL
Incoming Server Type: IMAP4
IMAP4 Server: imap.gmail.com
IMAP Port: 993
APOP login: greyed out
Download Limit: 500
IMAP4 incoming email: New
Retrieving option: Whole Message
Keep on server: checked
My email adress: [email protected]
hotmail.co.uk (This is the adress
the phone puts in the from line of
an email)
Username: [email protected]
Password: gmail password
Pop before smtp: greyed out
SMTP auth: checked
Same as POP3/IMAP4: checked
Username: greyed out
Passowrd: greyed out
This should allow you to recieve
new messages from the time you
set up the gmail account on your
phone and to send emails with all
the appearences of coming from
your hotmail account while
actually coming from google's
smtp server. Really do check that
the GMail is set up properly, make
sure it recieves emails adressed
to your hotmail and that it sends
in your hotmail account's name.
Posted on Apr 17, 2011
How to setup my gmail on samsung gt 3 2120
Find the Gmail icon in the Apps list. Here is the most confusing part. The icon on the left is the Gmail app. The icon on the right is the icon for all your other e-mail accounts.
2Tap the Gmail icon. Because your phone does not know if you have a Gmail account, it asks you whether this is a new account.
3Tap the Existing button on the screen. This brings up this screen.
4Enter your existing Gmail user ID and password. Go ahead and type your e-mail account address and your password. When you are ready, tap Done on the keyboard.
You may get a pop-up re-confirming that you agree with the terms of use and all that legal stuff. Tap OK. You'll see lots of flashing lights and whirling circles while your phone and your Gmail account get to know each other.
If everything is correct, your phone and your account get acquainted and become best friends. After a few minutes, they are ready to serve your needs. If you have a problem, you probably mistyped something. Try retyping your information in again.
From this point on, any e-mail you get on your Gmail account will also appear on your phone!
Nov 04, 2016 | Samsung Cell Phones
What is the password of this email address? [email protected]
The only one to know the password is the person who did setup the account. Looks like it is you.
If you did not setup the account, nobody ever can tell what the PW is.
If you did setup the account, you can ask google, on the Gmail login screen, to help you, by clicking I forgot the password. Then they will send a mail to the address you gave them while setting up this account. If it is not your account the real owner, will get the mail to reset the password and / or a mail, someone is trying to hack into the account.
Oct 01, 2014 | Samsung Galaxy Tab 3 7.0 3G T211 8GB-White...
Not able to setup Gmail A/c on my windows based Samsun Omnia Pro B7320. Please advice step by step process to follow. Also provide Server and necessary IP Details
Samsung Omnia Pro B7320 use Windows Mobile 6.1 . The WM 6.1 accept only application (.cab) , there's no application developed by google to use gmail as a application .
But I will give you how to Set Up Push Gmail on your Windows Mobile Phone :
To add a Gmail account to your WM and push notification :
  1. Launch ActiveSync on Windows Mobile device (under Start or Start '`programs.)
  2. Tap set up your device to sync with it
  3. Enter "m.google.com" under server adress
  4. Make sure this server requires an encrypted (SSL) connection is cheked.
  5. Tap Next.
  6. Type your full Gmail adress under user name:
  7. Type your password under Password:
  8. Enter "google" under Domain:
  9. Choose Next
  10. Make sure E-mail i checked.
  11. You can also check contacts and calendar to sync your address book and calendar with your Gmail contas and Google Calendar respectively. Make sure you have backed up your existing Windows Mobile contacts and calendar.
  12. Tap Finish.
  13. Select Sync.
Jun 17, 2011 | Samsung Omnia Pro B7320 Smartphone
I am unable to setup my email wizard in my samsung corby
Standard instructions for email inbox setup:
i have finished my corby pro email settings & i can send and recieve emails. the problem with only recieving & not able to send is the confusion between port numbers. in secure connection box three options available ' off ', ' SSL ', ' TLS '. use only SSL or TLS because the port numbers for SSL & TLS differs. just try this & you will be able to send and recieve emails.
                                                    SMTP port - 465
                                                    POP3 port - 995
Enable POP in Gmail. Don't forget to click Save Changes when you're done.Configure your client to match the settings below:Incoming Mail (POP3) Server - requires SSL:pop.gmail.com
Use SSL: Yes
Port: 995Outgoing Mail (SMTP) Server - requires TLS or SSL:smtp.gmail.com (use authentication)
Use Authentication: Yes
Port for TLS/STARTTLS: 587
Port for SSL: 465Account Name:your full email address (including @gmail.com [email protected]_domain.com)Email Address:your email address ([email protected] [email protected]_domain.com)Password:your Gmail password
Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587.
You're now ready to use POP with your Gmail address.
Mar 08, 2011 | Samsung S3653 Cell Phone
Plz provide me the settings of push email of gmail account in Samsung monte S5620
You have to have your service provider explain it to you because each phone is different. I wish you Luck.
Nov 15, 2010 | Samsung S5620 Cell Phone
How to set up a Blueyonder.co.uk e-mail account on my new samsung wave phone
Step to setup an email account on Samsung wave:
1. Press Menu
2. Select My Accounts
3. Choose the type of email account you want to configure . For Gmail, select "Google "
4. Enter your e - mail address and password and click " Next "
5. A new window pops up. Select apply without making any changes.
You will need to configure your Gmail for IMAP or POP pushing first before authorization is given to your Wave to accept the pushed mail.
Login to Gmail -> Setting (top right hand corner) -> Forwarding and POP/IMAP -> Check Enable POP for all mail arriving from now on and check Enable IMAP.
You are done with configuring GMail side.
Now, add your google mail account under "My Account".
Enter your email (username will be filled up automatically), then your password.
Next, when you hit the next screen, DO NOT CONFIGURE ANYTHING. Simply "Set".
Make sure u have POP and SMTP enabled in your mail account before you try this and yahoo users make sure u enter your mail address as that of your domain
example : [email protected]
where xx can be something like uk or us or in etc
Nov 01, 2010 | Samsung Cell Phones
Unlock samsung e2550 monte free
How can I unlock my Samsung E2550 phone Thanks
Sep 09, 2010 | Samsung Lands Phones
How to setup gmail on as the push mail for samsung monte
how to start push mail service on samsung monte
Aug 16, 2010 | Health & Beauty
Health & Beauty Logo
1,579 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
