Question about Russell Hobbs 3902US Work Top Blender
Leaking from around the base of the jug - Russell Hobbs 3902US Work Top Blender
Posted by junewatts7 on
Anonymous
    New Friend:
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Posted on Sep 20, 2010
2 Related Answers
Anonymous
  • 31 Answers
SOURCE: liquid leaks from base of blender jug of tefal
gasket not seated around the blades, or worn out
Posted on Jan 07, 2010
Paul Bade
  • 1666 Answers
SOURCE: My daughters blender leaks between
There is supposed to be a flat rubber ring that goes there, at least there is on my blender.
Posted on May 30, 2011
Gold powder or particles on base
It's probably brass, run it a few time and clean it, if it continue, their a good chance that your bearing is dying (grinding it self),check if you can replace that section.
Jan 06, 2014 | Breville Blenders
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
My daughters blender leaks between the jug and the base Is there a seal missing tks
May 30, 2011 | Blenders
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Russell Hobbs 3902US Work Top Blender Logo
743 people viewed this question
Top Russell Hobbs Blenders Experts
Marvin
Marvin
ray gallant
Tom Chichester
Are you a Russell Hobbs Blender Expert? Answer questions, earn points and help others
