I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
I assume you have no paper feed issues.
There are 2 places that you can place paper, and a switch to choose which one you are using.
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
