I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
Posted by greggkr on
Steve
    Novelist:
  • 120 Answers
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Posted on Sep 20, 2010
To hook up gas, to an Vulcan 260 freeloader
best left to a pro . gas leaks cuase explosions when we certainly don't want one
Jan 21, 2015 | Water Water Heaters
Vulcan freeloader 260 suddenly turns off after heating to temperature. Control unit was just replaced but still doing the same. I was told by another person it is the thermo couple but the fitter said
The thermocouple makes sense, if it does not send enough electricity to the control unit it will shut off. The thermocouple was probably moved when a new control unit was installed. Check to be sure the pilot flame touches the thermocouple, if not realign it else replace it.
Mar 25, 2014 | Water Heaters
We are getting a brown colour in our hot water from our Vulcan freeloader (assume this is where its from anyway). Is this a fixable problem or will we need to look at a new unit? The current unit is about...
unfortunately there is no fix other than replacing the tank, it has a lot of rust buildup inside over 18 years, which is a very long time for a hot water tank today.
Aug 30, 2011 | Water Heaters
Hi I am renting a house with a Vulcan freeloader 260 outside boiler. We keep finding that we do not have any hot water, we turned the thermostat dial up and this seamed to fix the problem for a few...
The unit may be undersized for the amount of water you are drawing off. The freeloader is a storage system. As you draw water off, it fills with cold water. On a 260 its not unusual to use at least half that on a long shower, or if someone else ahs the hot tap going. It takes around 30 minutes to reheat the misplaced water up again...
Jul 16, 2011 | Heating & Cooling
Can I replace the pilot light on a Vulcan Freeloader 260 gas HWS?
Hello...how old is the unit? Today it is very common for gas appliances to have electric igniters instead of a pilot light. Unless you are familiar with gas controll/regulator valves I would not recommend trying this yourself. I believe it is more likely a faulty or dirty thermo-couple. Again , unless you are familiar with the opperation of gas supplies ,controls ,etc. DO NOT ATTEMP to do this yourself!!! Gas is very dangerous for the less than well informed! Call a service pro or speak to and ask for the assistance of a knowledgable friend.
Feb 14, 2011 | Water Heaters
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Water too hot on a Vulcon Freeloader Super 10
Remove the cover and there should be a temp setting
Jan 31, 2009 | Water Heaters
Heating & Cooling Logo
587 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
