1999 Chevrolet Silverado 1500 Logo
Posted on Sep 19, 2010
1996 Chevrolet K1500 5.7 auto. Stumbles only under load. Idles,starts fine, will only gently accelerate with light pedal, engine loses power when medium or heavy accelerator pedal action only when in gear,. New coil, plugs, wires fuel pump, screen and filter. had misfire code 0300 and TCU code 0700 and an undefined code of 1192. Has o2 codes 0157,0151,0137,0131. cleared codes and only 0700 and 1192 stored.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
728
Points
You might check out the transmission. 0700 is a transmission code. You may not be getting a down shift.
4answers
Why does my truck lose power and won't accelerate
its probably a clogged up fuel filter if not your pvc valve vaccum try that good luck
2answers
Idles great no throttle response
first check make sure it's not flood out 2 check high speed idle if it has one
Loses power on accelleration
run fault codes and look for MAP/MAF sensor and accelerator position sensor problems
My 2001 Camaro idles really rough, loses power when accelerating, and the check engine light starts flashing.
ALUMINUM V8 CAMAROS HAVE 3 PROBLEMS
1 VACCUUM LEAKS ie HOSE TO THE pcv deteriorates
2 MASS AIR FLOW / hard to diagnos sometimes
3 COLLANT temp sensor, ie starts fine cold, crappy when warm
1helpful
I have a 1997 lumina with 3.1L. the problem started with loss of power under load and p0300 code. check coils and vacuum leaks both OK.change spark plugs and wires.[same problem] check compression OK.
Since you changed the sensor we will assume it is working. When you disconnect it you put the computer in limp mode which stops it from using sensor values. If code 300 is the only code we will assume the coolant temp sensor and others are ok.
I would check fuel pressure with a gauge next.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
