Zenith C27A24T 27" TV Logo
Question about Zenith C27A24T 27" TV
I have a 27 inch Zenith tv and would like to know what it means when I pulg it in and get a continuous beep.
Posted by mneals on
geek2010
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
It could be the internal processor is malfunctioning creating the beep. This could mean the tv is on its last leg.
Posted on Sep 28, 2010
Because I like this zenith 27 inch TV large black TV
im sorry I cannot deliver any thing. I was just helping fix things that was broke and saving people money because most things can be fixed at home very cheap instead of paying 300 dollars for a repair on a 2 dollar part. sorry if I could I would for sure.
Zenith 27 inch text is blurry
This tv needed CRT Tube discharge.Take the tv aparts,take out the CRT video board,must plug it back in."Highvoltage becareful",find a wire with good insulations,grounded itself in with a screw from a steal frame.High voltage "Take that wire go close to the CRT tube without the video board connect in.Than u will hear a pop,that the highvoltage,just discarge ur CRT bad contamination.The tv should be clear now,after putting it back together again,getting it working.
1helpful
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
No Original Remote , Which substitute
Required remote for your TV is available HERE.
Tv picture is shrunk to the middle of the screen and turns off
if you mean line across middle no vertical deflection prob circuit prob. need tech.
Zenith 27"h2521y3
Hi
What do you mean?
thanks!
H.V shuts down/
try to check a bad conections in hv transformer and capacitor around them
Zenith 27 Inch Sentry 2 i think
yes let me know if you still need help on this one it is in factory defalt, i will look up service manual and let you know the codes to make it a regualr tv again, they have it set to display setting.
Tv blew up
sounds like the typical power supply or sweep problem in the zenith chassis. depending on how old this set is will determin if its even worth trouble shooting or taking it in to be looked at by a pro. If your not experienced with tv repair i would call a repair shop or take it in as tv sets have high voltage stored in them even after they have been unplugged for a while. If youve tinkered with tvs in the past or know someone who does zenith tvs are made for a complete chassis exchange. you can Call PTS Corp at 1 800 844 7872 and see how much an exchanged referbished chassis would cost and go from there. Good Luck
Top Zenith Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
