Question about Hotpoint Ultima WF860 Front Load Washer
How do i turn off demo mode on my dishwasher - Hotpoint Ultima WF860 Front Load Washer
Posted by derek_davies on
Dominic Parsons
    New Friend:
  • 118 Answers
To remove the demo turn the power off at the plug, hold in the power and reset buttons and turn on at the plug.This will reset the dishwasher. ps if the power and reset are pressed in together it will bring in the demo mode. If this does not work try Holding down the on/off button and the cancel button at the same time till says D OF. Hope this helps.
Posted on Sep 19, 2010
1 Related Answer
Anonymous
  • 34 Answers
SOURCE: how do you turn off demo mode on hotpoint ultima
Hello leedowns1,
You can take it out of demo mode by pressing the "on/off " and "start/reset" button together until "d of" appears. Hope this fixes your problem.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
Posted on May 02, 2009
My electrulux dishwasher is stuck on control demo
Try these steps to resolve your demo mode concerns:
Demo menu is invoked by holding the Select Option and Right Arrow keys for 5 seconds.
Arrow to the DEMO ON option in the demo menu.
Press SET to turn off the demo feature. DEMO OFF will be displayed.
At this time, all outputs are operational.
To return to normal operation, press and hold Select Option and Right Arrow keys for 5 seconds.
Let me know if you have any problems or something does not appear to be correct while doing the above. Thanks!
Mar 30, 2013 | Electrolux 24 in. EDW5505EPS Stainless...
Control demo
Hello - If the unit was in demo mode it would not produce any water or rinse actions. So if you have water entering the unit, I doubt it is at all in demo mode. Error E01 for Electrolux models means the unit has detected a water leak. This will need to be checked and a repair performed by a technician since they will need to repair the leak and retest unit.
Oct 13, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
How do I get Electrolux dishwasher out of control demo mode
-Demo menu is invoked by holding the Select Option and Right Arrow keys for 5 seconds. -Arrow to the DEMO ON option in the demo menu.
-Press SET to turn off the demo feature. DEMO OFF will be displayed. -At this time, all outputs are operational. To return to normal operation, press and hold Select Option and Right Arrow keys for 5 seconds
Sep 08, 2012 | Dishwashers
Seems to be stuc in Demo mode and refuses to do anything except select programs
the way I clear a cycle on my FDW50 is to open door,push and hold cycle selector and cycle start until you hear prolonged beep followed by three short beeps-this will cancel whatever has been selected
Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
I have a KitchenAid model KUDP01FLBT6 dishwasher. When hitting the "Normal" button and the "Start" button, the dishwasher would run for less than 5 minutes and then shut off. Dishes...
what makes you think it was in a demo mode ?? was it a floor demo model ? as if it was there might be a few things you needed to reconnect before you use it in your home , one that comes to mind is the float level switch , this is usually in front right corner and demo models usually have a foam spacer under there edge , also its possible a demo model could have a special control board in them , requiring you to replace it with a standard model b4 it would work properly
May 27, 2017 | KitchenAid 24 in. KUDP01FL Built-in...
How do you turn off demo mode on hotpoint ultima dishwasher
Hello leedowns1,
Thanks,
edgin96
May 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Turns on for 30 seconds, then turns off,not let me cancel/drain?
unit is in sales demo mode.
push in less than 3 seconds:
High temp - heated dry - heated dry - high temp - heated dry - heated dry
to switch demo mode off
Feb 23, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Ultima WF860 Front Load Washer Logo
407 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
