Question about DeLonghi CC 80 Coffee Maker
I have a 10 year old Delonghi coffee/capucino maker and have lost the emulsifer - small grey rubber piece with 2 holes. Where can I find a replacement? I am told Delonghi can't help as they no longer make the appliance. I could not find a model number however it is Type CC 80 IU and Serial # 2 30 10
Posted by lynn_varga on
5 Related Answers
Anonymous
SOURCE: My DeLonghi DCM485 coffee maker
The same thing happened to me....At least you got three years out of yours, I got three months.
Posted on Sep 11, 2008
Anonymous
  • 110 Answers
SOURCE: Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
Posted on Jul 02, 2009
MikePurcell
  • 10 Answers
SOURCE: My deLonghi Magnifica EAM3200 coffee maker is
I have the same problem, it leaks all over the place and makes a mess inside. Initially it just seemed to leak steam but it got worse and worse until now it leaks water badly. I took it apart and it appears to be a small orange silicone seal that's bad. The seal is located on the plunger that compacts the grinds and then forces water through to make the coffee. I took mine completely apart but I think by using a stubby Phillips you could remove the small black cap and replace the O ring easily. The O ring on mine that is torn is about .35" OD and about .15" ID.
To check if this is the problem on yours; turn off the machine and remove the main filter unit by pressing the two red "press to remove clips" and pulling the unit out. It will not come out with the machine powered on. Now look up into the top right hand corner and you''ll see the plunger and heater unit angled towards the center of the machine. There are two small stainless countersunk Phillips screws. Remove these and you should be able to see the small orange silicone O ring in question. Might be a good idea to replace the large one as well as it now pops right off and you can certainly clean around it now, something I was never able to do before. My small orange silicone O ring was torn into two pieces and I'll replace it tomorrow and see if it helps.
Posted on Jun 14, 2010
Anonymous
  • 5 Answers
SOURCE: DeLonghi BCO120T coffee maker side does not work.
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Posted on Sep 30, 2010
Anonymous
  • 473 Answers
SOURCE: I have a DeLonghi Caffe Firenze coffee maker
Well Try To download it From Google.. Exemple download Delonghi Bar 8 Espresso Manual Utility ...then choose The right One for your Model Good Luck
Posted on Oct 07, 2010
ESAM6600 will not froth milk
Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath
I had frothing problem as mentioned above and noticed this tube was blocked, its 4 years I have had the Gran Dama 6600.
Cleaned as mentioned and did some purge as I went along, now it works as new. Its a maintenance that should be done once a year. You learn as things happen. LOL
Mar 17, 2012 | DeLonghi EAM3500 Espresso Machine/Coffee...
My < year old DeLonghi
If the light comes on and the coffee is not brewing than it is the heat plate temperature fuse. You need tamper torx bits to open the bottom unit and replace the fuse, radio shack sells them. I have had to change several of these on Delonghi products. These are mechanical connections and the leads need to be crimped properly or the unit will fail.
Mar 12, 2011 | DeLonghi Coffee Makers & Espresso Machines
I lost my instruction booklet. How much coffee should I use?
On the side of my coffee container it says,
"For all coffee makers.
  • 1 tablespoon 1 serving
  • 1/2 measuring cup 10 servings.
Of course, you can adjust according to your personal preference for coffee strength.
Dec 05, 2010 | DeLonghi 60 CUP COFFEE URN Stainless steel
Suddenly my esam 4400 does not give the milk to make cappucino although I have cleaned everything very carefully. what can be the problem?
i have the same i spent 1200 euro on this stupid machine, after 3 months no more frothed milk! we bought it sepcaillly for the capucino
Aug 22, 2010 | DeLonghi EAM4000 Espresso Machine
The water drips out excessively at the top, there is asecond hole where it comes out
When this happened to me, I found that the filter basket had worn and wasn't lining up to catch all the water from the bypass line. I used a small rubber rod behind the lower connector post (where it attaches the basket to the coffee maker) and that forced the top of the basket back far enough to catch all the water. I am using that until I can find a replacement basket.
Aug 05, 2010 | DeLonghi Caffe Nabucco BCO70...
I lost the mesh filter on my DeLonghi Caffe Elite coffee maker. How can I obtain a replacement?
Since nobody could tell me where I could purchase a replacement mesh screen folter, I now use 2 paper filters and that seems to work reasonably well.
Apr 18, 2009 | DeLonghi Caffe Elite DC76T Coffee Maker
Commercial bunn coffee maker that the water only dribbles out
In addition to running vinegar thru your coffee maker, remove the sprayer at the point where the fresh coffee comes out to enter the carafe. It is a disk about the size of a half dollar with several small holes in it. Use a small piece of wire to clean out each of the holes and you should have the speed back. good luck.
Jan 27, 2009 | Bunn Counter Top Coffee Brewer Commercial
Un-used deLonghi Caffe Nabucco
Please follow this LINK
Than go to instruction manuals.
Food preparation. Coffee and espresso makers. And click on BCO70
that will give you your instruction manual
Jun 14, 2008 | DeLonghi Caffe Nabucco BCO70...
Leaks
Same problem here. I did get it apart and there are two metal water lines each connected by a rubber fitting that is just slipped on. My guess is that as the rubber connectors get old they start leaking water. I'm going to try putting a small worm clamp on the bottom half of the rubber connectors to see if it stops the leaking.
Jan 13, 2007 | Braun FlavorSelect KF 180 Coffee Maker
DeLonghi CC 80 Coffee Maker Logo
194 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Jeffrey Groves
Jeffrey Groves
kltcoco
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
