The OE is an overload error. Try removing some clothes. If that does not work you could try unplugging the machine. I have a manual you might want to look through. LG washer manuals
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code. The grinding noise you are describing is most likely a failed drain pump or clogged with foreign debris.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
