Question about Canon Rebel XT / EOS 350D Digital Camera
Windows 7 will not acquire pictures from camera
Posted by rmjeagle1 on
Anonymous
Buy a eye-fi wireless memory chip you will have wireless transfer of you photos.
Posted on Sep 19, 2010
Software (not driver) for camera
There should be a Windows app in your Start Menu Programs folder named "Camera". If not, a search of Cnet or Download.com should find a free program to access the camera. Some programs will let you acquire images from devices and you can select the camera there.
Jan 08, 2018 | Intel Pro PC Camera CS430 Webcam
Sir, i'm using AOC V22+ screen 4 my pc , i cant install the drivers 4 web cam given by AOC , i 'm using windows 7 os , its not installing , so what should i do now , plz give me assistance
The web camera requires a program that recognises features, and provides windows opportunities to allow captures of pictures or movies. Acquire a new camera program an to a driver. The computer requires a program usually to function, requesting a driver is not achievable in this situation.
Feb 09, 2011 | Computers & Internet
Changed from windows xp to windows 7. I can't acquire images to my computer using lumix simple viewer. I think I need a windows 7 driver for my camera but I don't know how to obtain the driver.
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 01, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I am using Windows 7. When I try to acquire from PC, the word "ACCESS" flashes on the DMC-FX8 camera screen continuously but the Lumix View Finder cannot find any pictures. How can I solve this...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 28, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
When I acquire pictures from SD card, it acquires
You shouldn't be leaving the old pictures on the card. That's a guaranteed way to get into trouble. After downloading your pictures, format the card in the camera.
If you want to transfer just the new pictures, you'll have to select those pictures for transfer. Since you declined to specify what software you're using, I can't tell you precisely how to do that.
May 15, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
The only way is to use a separate card reader. When it opens on your computer, select the new pics and drag and drop them where you want them.
Mar 27, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
How to acquire videos from camera?
very simple. you need to get an SD card reader from your local electronics store ( CC or Best buy). it's very simple. the memory card goes into the card reader and that ensemble plugs into any of the usb ports in your computer. once plugged in, the computer will recognize it as external memory, just like a flash/thumb drive and your comptuer can read the pictures off of the card without any interaction with the camera itself. you will be able to see both the picture and video files on the memory card. all you will need to do is copy the pictures or the videos, and paste them into any folder you wish. your computer should have no problem recognizing those files. and windows media player should not have a problem reading the video files either. with them on your computer you can just drag and drop them into any video editing software that you have. i have a canon sd750 and that's exactly what i do. works like a charm.
Aug 31, 2008 | Canon PowerShot A550 Digital Camera
Acquire pictures from Panasonic Lumix DMC-TZ3
hello!
When your camera connected to the computer. the computer create drive maybe designate as drive d: or e: or any drive created by windows.
connect the camera to the computer. after connecting to the computer go to the my computer and the browse the drive created : browse until u see the pictures files. and then click view to and select thumbnails. now u see the picture preview. select the file want to copy and paste it anywhere you want (your folder). your own way.
melnavz
Mar 18, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Not acquiring pictures with any software
don't think it was the cable, they are a standard usb interface cable.
Had a similar problem, when I installed software for a new camera interface.
you can manually open the cannon software once the camera is hooked up to your computer. Its called "camera window" default install is start>all programs>cannon utilities>camerawindow>poweshot>camerawindow
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
How do I the delete images so I can re-use the memory card?
To delete photos from the SmartMedia memory card in your camera, you must first download them to your computer. Follow this procedure to transfer your photos from the camera to your computer: 1. Make sure that your PDC 640 is connected to your computer and both are turned on. The "PC" icon should appear on the status panel on the top of the camera. 2. Open the PhotoMAX application on your PC. 3. Click Get Photo. Note: If you are using PhotoMAX Pro to transfer pictures, you need to select PDC 640 Camera from the Select Source dialog box (select File > Acquire > Select Source), and then select File > Acquire. 4. Click Album or flashPath. 5. Select the album in which you want to save your images, or click New Album to create a new album. 6. Click Camera or Scanner. 7. Select PDC 640 from the Sources list on the Select Source window, and then click Select. The PDC 640 Twain Driver window opens. 8. Click Get All to transfer all the images in the camera memory to your computer, or select the images you want to transfer to your computer and click Get Selected. The images are transferred to the selected album, which is located in the PhotoMAX Albums folder. The PDC 640 Twain Driver window closes. 9. To edit a picture, double-click the image in the album that you want. The image appears in the image tray.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
113 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
