SOURCE: 1992 geo metro, can only
Sounds like the timing is retarded. When was the last time the timing belt replaced. The timing belt is wearing out and stretching causing the timing to ****** itself.
SOURCE: Blown coil fuse
IG fuse powers: daytime running lamps(DRL) module; transaxle control module; A/C amplifier; main, fuel pump, and radiator fan relays; alternator; heated oxygen sensor; ignition coil, ignition noise suppressor; sensing and diagnostic module(airbag); audio alarm module; and just about every gage and light in the instrument panel; so there are no usual suspects. The best you can do is try to rule out these components one by one. There is a breaker you can buy that plugs in the fuse hole, that way you can **** around with it without wasting three dozen fuses.
SOURCE: where is the fuse for the cigarette lighter in 99' Chevey Metro
I have a similar prob with this crappy lighter. The lighter & radio run off the same fuse.
The fuse block is located near the hood release lever, under the dashboard towards the left side of the car. It's about 6" x 3" and white plastic. Can't miss it. The cover snaps off and the fuse is blue colored and 15 amp (says 15 on it).You can buy a pack of 5 of these at Walmart for about $3.
Looking at the fuse block, go to the furthest left verticle row of fuses. It should be the last or next to last 15 amper from the bottom. You will need needle nose pliers to pull it out.
Make sure ignition is off and start pulling 15 amp fuses, one at a time from the bottom then moving up and check to see if they are blown. You shouldn't have to pull more than 4 of them to find it.
What I plan to do is splice and aftermarket (Radio Shack) inline fuse into the hot or + side of the lighter wires. This way, hopefully if the lighter shorts, it won't take the clock and radio with it and will be much easier to replace the little "barrel" style fuse. Just make sure it's 15 amps. Hope this helps. ♥♥♥♥
LJA
SOURCE: Automatic Transmission 97 metro
Hi:
Specifically, you remove the transmission dipstick and use a narrow funnel to pour transmission fluid in the transmission till it is full. Remember to check your fluid level after the transmission is warmed up, and the car is running, gearshift in Park.
Testimonial: "Thanks!! I thought that might be it as I couldnt find a place to add, like the engine oil has..."
SOURCE: how do i chage the fuel injector for a geo metro
REMOVAL & INSTALLATION
Fig. 1: Removing injectors from fuel rail
Fig. 2: Make sure injectors rotate freely in cylinder head
