Dell inspiron 6400 problems switching on power After switch on the poweer button .. One led is staying on and other two led is blinking after sometime all led light gone off.. Please advice me to trouble shoot this problem.
Posted by nayakaron on
Mohamed Omran
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Posted on Sep 20, 2010
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
Inspiron 6400 is not getting started
Adapter should be faulty,kindly check with one another.
if again you are facing the problem might be short circuits in the motherboard
regards,
pp
Inspiron 5100 after replace battery back-up power on and no screen display and the last LED opposite side with the power LED stayed on
try removing the battery, holding down the power button for 1 minute, reinserting the battery. this may help clear up any issues you have.
Hi, My Dell Inspiron is not switcing on. when pressed the power on switch. power on light come on for a while and goes off. can i get support for the fix
not switching on? that likely means you have a system board issue, or a cooling system issue. if the cooling fan doesnt spin, some dells will stay off or turn off, to preserve the processor. In either case, unless you are a tech, I would take that machine to a shop.
Dell inspiron 6400 problem in switching on
hi there so once you see the dell logo keep on tapping f8 and check if you can enter the safe mode, if not tell me the lights because that means thats its a no post issue and we might need to reseat your memory.
DELL inspiron 6400 not switched on
This is a no boot issue. Youre saying that you can perfectly run the PSA diagnostics but doesnt load Windows rather it stays on black screen, meaning the boot loader of Windows failed to load. You need to reinstall windows on your computer
Switching on the laptop
Try holding the power button down for about 10 seconds. Then try turning it on.
Next remove the battery and try to start with just mains power.
Next replace the battery in the computer and let it charge.
If this does not work you will probably have to contact Dell
1helpful
6answers
Dell Inspiron 6400 Power Problems
Sounds like the power pin is either loose or damaged. . . .Happens from jerking or tugging on the cord too much.
Once you get it fixed you need one of these. . .
Computers & Internet Logo
Ekse
