AOC 7F 17" CRT Monitor Logo
Posted on Apr 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IMAGE SETUP AND IMAGE DISTORTION PROBLEMS After
IMAGE SETUP AND IMAGE DISTORTION PROBLEMS After the monitor's menu started appearing from nowhere, it reconfigured itself, altering the image setup in the process: Horizontal, Vertical heights and sizes re-adjusting themselves, racing to and fro like the monitor's circuitry has gone loco. Every so often it pauses, but resumes re-adjusting until the result becomes so visually grotesque. Brightness and Contrast have joined the fray, and relents only after achieving the brightest image at 100. The Image Distortion Options have left the screen with an awful shape and caved-in borders.
Larry Ng
Level 3:
Top Expert:
  • AOC Master 14,591 Answers
  • Posted on May 03, 2022
Larry Ng
AOC Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3277835
Points
66570
The last cathode ray tube on earth, running
we dumped these in the year 2000
LCD
why not you> ,
last person with vacuum tubes?
2 Related Answers
A
Anonymous
  • Posted on Jun 21, 2008
SOURCE: contrast menu
don't buy this type of monitor because i have same problem as you... i realy hate this monitor...
Anonymous
  • 128 Answers
  • Posted on Oct 22, 2008
SOURCE: Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
How do I adjust the image width on this wide screen? Everything appears distorted and wider than it is. I would like a narrower image.
This is one of the problems with the wide aspect screen. Most images seem to fit best on the older monitors.
You can go into the video properties and choose one the the display types that best display your image. Unfortunately, by taking a normal (to us) image that looked just fine on an older monitor and displaying it on a newer, wide-aspect monitor, you're gonna distort the image or crop it in a way you didn't expect.
My advice is to experiment with the display until you find something you can live with.
tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 • Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
My laptop monitor gets distorted
First must make sure that the problem in the screen and not in the card Alclcp by connecting the device to screen Hargip if the image is good to be change the screen
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Screen jumps back to prior screen
If you mean to say that the computer-generated displayed image on your screen changes, it's a function of the computer, not the monitor. If you mean to say that some monitor-generated displayed image is appearing (such as a setup/configuration menu or a splash screen), please tell us more so we can diagnose further.
Screen appears squeezed from left and right sides
Sounds like the video card settings are over-riding the monitor settings. Go to display settings in control panel, and try the one that says "recommended". The other thing I have found out is sometimes the monitors start doing strange things before giving out completely.
1helpful
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Panasonic TH58PX600U 58 in. HDTV Plasma. Image is Distorted
I could not see the image you say you included in your description. If the rectangle is black (and not just an outline) it may be the box associated with captioning or text descriptions. Use your setup menu or remote control to turn captioning/text off.
Monitor distortion
Hey edwardaaron,
If you are encountering any kind of visible distortion on your computer monitor, there are a couple of things that I would suggest.
First, if you have a cathode ray tube (CRT) monitor, you may want to try manually degaussing the monitor. Whenever a CRT monitor is in use, it slowly builds up a magnetic charge that can interfere with its operation. Degaussing then, is the process by which CRT devices rid themselves of this excess magnetic charge. This is normally done whenever a monitor is first turned on, but many monitors will also have either a button on the front control panel you can press or an option in the main menu to perform a manual degauss.
In many cases, the degauss option will be marked with a horseshoe or magnet-shaped picture. Once you've selected this function, you may notice a metallic-sounding "twang" noise, followed by one or two "clicking" noises as the image on the screen is reset. Keep in mind that images on the screen may appear to vibrate and color may distort for a few seconds after you do so, but this is a normal part of the degaussing process. The screen should return to normal after a few seconds.
Second, interference can also be caused by placing your computer speakers too close to the monitor. Many speakers will produce a magnetic field of their own, which only adds to the magnetic field generated by your monitor. In this case, repositioning your computer speakers should help minimize the problem.
If degaussing fails (or you don't have a CRT monitor), you may wish to then test the cable connections to your computer. In some instances, simply replacing your monitor cable will resolve these types of problems.
You may also be encountering a problem where your monitor is simply set on the incorrect refresh rate. If the refresh rate is not correctly set, a monitor may display a "wavy" image or appear as if lines are periodically scrolling across the screen. Without knowing the exact make and model of your monitor however, I would not be able to provide any suggestions on how to change this setting - you would need to contact the manufacturer or refer to your owner's manual for specific instructions.
The worst case scenario would be if you are encountering an actual hardware failure. Both the video card and monitor can cause images to be distorted if they are not functioning properly, and even power supplies have been known to cause other components to sporadically malfunction. If you are unsure how to perform a hardware diagnostic, I would strongly suggest speaking with your local computer repair technician or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
