Macromedia Flash MX Logo
Question about Macromedia Flash MX
I have download Adobe Flash Player 10.1 worked for about 15 minutes and then it said my Adobe Flash Player 10.1 was damaged
Posted by latinkings_4 on
Anonymous
    New Friend:
  • 16 Answers
Go to control panel add and remove programs remove that version of mozilla and reboot computer go back online try to download from a different location try to reinstall reboot computer try it out see if that fixes it good luck let me know if this helps!
Posted on Sep 19, 2010
Need adobe flash player 10 for iPhone
adobe flash player 11
http://download.cnet.com/adobe-flash-player/3000-2378_4-10001055.html
connect your iphone to your computer and download
hope it helps
I upgraded my internet browser now some of my games won't come up because it says my adobe flash player is not there.
yes u have to install your flash player again for that go to adobe.com and download adobe flash player from here you will install it in 5 to 10 minutes easily
2helpful
Downloading adobe flash player be come a problem on my computer
When you download and install Flash Player from the Adobe Flash Player Download Center, the download uses the Adobe Download Manager. Instead of using the Adobe Download Manager, you can download and run the Flash Player installer manually.
  1. If you haven't already done so, Uninstall previous versions of Flash Player.
  2. Select the manual installer depending on the browser you use. Select one of the following:
  1. A File Download dialog box appears. Select Save. (If you are using Firefox, select Save File).
  2. Print these instructions and then close all applications.
  3. Open the folder in which you saved the file.
  4. Double-click the file name to run the manual installer.
  5. Select the license agreement and then select Install.
  6. When the installation completes, select Done.
  7. Go to http://www.adobe.com/software/flash/about. If the installation was successful, the page displays the Adobe Flash Player version. For more information, see Determine the Flash Player version you installed, if any.
For more help, please check out: http://kb2.adobe.com/cps/191/tn_19166.html
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
My new packard Bell Onetwo M D6321 64 bit system will not function with Adobe Flash Player 10 Active X. Im using internet explorer (64 bit) as my browser. Adobe website keeps leading round and round...
The component is named 'ActiveX'.
The version of the Adobe Flash Player was 9-point-something, but now
the current version of the Adobe Flash Player is 10-point-something.
So, use Add/Remove Programs to _remove_ Adobe Flash Player.
Restart your computer.
Access: http://www.adobe.com/software/flash/about/
and allow the ActiveX control downloaded from Adobe to be installed.
Im trying to install an updated flash player (adobe 10)
Click Start.
Click Settings.
Open Control Panel.
Open Add/Remove Programs.
Highlight Adobe Flash Player.
Click to remove it.
to download the most-current version.
1helpful
2answers
How do I install free adobe flash 10 player?
goto www.adobe.com. and click on download flash icon.
everything else is self explanatory and user friendly.
Tried both solutions adobe flash player 10 still failed to register
You may need the latest Java Updates. Go to www.sun.com and download the latest Java Console to your computer. After installation, try to download Adobe Flash Player again. If it does not work then your operating system may not be compatiable with Adobe Flash Player 10. You may need to download an older version such as Adobe Flash Player 9.
You can find older versions of Adobe Flash Player such as 9 on www.cnet.com type in the search field (adobe flash player 9). After the options show up, choose the file to download and install.
Be sure to check your available memory and system speed which are also factors when installing flash software.
9helpful
My farmville FARM will not open - adobe flash player problem?
Installing Adobe Flash Player 10. Then go to C:\Windows\System32\Macromed\Flash. Then double-click FlashUtil10e to initiate setup.
11helpful
3answers
Show me how to download. adobe flash player
Go to www.adobe.com
look for adobe flash player and download it. or you may go to sites like espn.com or nba.com or any site where adobe is needed, click on the link that says flash player is needed. This will take directly to download flash player from adobe and just install it.
Top Macromedia Computers & Internet Experts
Rob Hill
Rob Hill
Muzahura Frank
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
