Linksys Wireless-G WRT54G Router Logo
Question about Linksys Wireless-G WRT54G Router
How to add apple McBook to secure network. Changed configuration to secure network and apple laptops cannot connect via wi-fi.
Posted by nanoaponte on
Anonymous
    Guru:
  • 382 Answers
You need to reconfigure your wireless network.
Better yet create a new wireless account, fillout the Authentication/Security Information.
Establish a wireless connection to that secured network.
Posted on Sep 19, 2010
Anonymous
  • Linksys Master
  • 32,281 Answers
The MAC network card needs configuring with the router's security settings ie. SSID and encryption code etc, otherwise it cannot connect to the router wirelessly.
I keep on getting an unidentified connection via my Huawei WiFi router with MAC address BC:41:01:4C:CF:89. What does this mean and how do I stop it?
mac address is an unique network device equipment identifier.
How to stop it. Change encryption key when you add wpa or wep encryption to wi fi security on router. Added security - do not broadcast ssid and change it to something different.
All devices with wi fi will need to be changed to match wi fi encryption method and key and ssid name.
tip
How do I delete the Wi-Fi from my iPod?
<p>IPod is a line of various models of media players made by Apple. The flagship of this line, the iPod Touch, includes the ability to connect to computer networks wireless 802.11b/g/n following international standards. Also, remember the iPod Touch Wi-Fi networks are members in the past, allowing the user to save the trouble of having to re-enter network keys and other authentication tokens. However, sometimes a user may need a specific Wi-Fi memory to remove the iPod Touch - for example, when the network configuration has changed. <br /> <p><br /> <p>1. Play your iPod icon "Settings" and then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that time, the iPod touch loses any memory connected to that network and configuration parameters of the past. <br />
on Aug 05, 2011 • Computers & Internet
Don't know how to connect to my home wifi
Connecting your Acer laptop to your home wireless network is fairly simple.
Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position.
Not all models have this switch.
Open the Windows Start menu and select "Connect To."
A list of available connections will appear.
Select "All" from the drop-down menu to view all available networks and connections within range.
Select the desired network and click "Connect."
Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
HOW DO I SWICH THE WIFI ON
Which model acer ???...
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
How to get phone on home internet
1. Click Set Up Wi-Fi.
2. Click Next.
3. Click Manually Add Network.
4. Type the network name or service set identifier (SSID).
5. Click Add.
6. From the Security Type menu, select the security type for
the Wi-Fi network.
7. Specify the required security credentials.
8. Click Connect to manually add and connect to a Wi-Fi
network.
Can not detect wireless network on wifi enabled
Make sure on laptop wi fi switch is turn on.
Uninstall wi fi network adapter driver then reinstall.
Right click on my network places and click on property then right click on wi fi adapter and enable it and click on view available wi fi networks .
If you still not detect signal of router then You hav to reset router.
For thjat press RESET button for 10 seconds it is in back panel of router.Then it defaults.
then connect router to computer with ethernet cable then you can access it with below link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Then set WAN settings as your isp.
GO to wireless settings and enable it .
If you want to secure enable WEP security and add wep code.
Enable DHCP.
Then save and restart router then check.
Let me know if you need further assistance.
Thanks.
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
2answers
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
http://1921.168.0.1
Thanks.
1helpful
2answers
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Top Linksys Computers & Internet Experts
Donivan Wise
Mike
Steve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
