Watches Logo
Posted on May 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sector 900 chronograph wristwatch. Sometimes, after using the chronograph and resetting it to zero position, the hand (large one) does not go to zero (position 12) but stops at e.g. minus 8 and then next time starts from there. I brought the watch back once and it was fixed in an instant. I have the same problem sometimes with another chronograph (not sector) and they explained to me that it can be easily done by myself, to reset it. Does anyone know the combination of keys etc to do so?
Kent Isom
Level 2:
New Friend:
  • Expert 24 Answers
  • Posted on May 24, 2017
Kent Isom
Expert
Level 2:
New Friend:
Answers
24
Questions
Helped
7079
Points
158
Easy, go to youtube.com and watch the video on How to.
5 Related Answers
A
Anonymous
  • Posted on Oct 02, 2007
SOURCE: SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
A
Anonymous
  • Posted on Dec 25, 2007
SOURCE: sector 255 need to contact sector
need help in setting time on sector 550 2653955025.
Anonymous
  • Posted on Jan 09, 2009
SOURCE: Sector 250 Chronograph Alarm
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
enjoy the watch!
Anonymous
  • Posted on Apr 13, 2009
SOURCE: Sector adv 1000 setting alarm
key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
Anonymous
  • 3 Answers
  • Posted on Aug 16, 2009
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
HOW DO I GET THE LARGE SECOND HAND MOVING .
If you have a large second hand and a small one then you must have a chronograph or stopwatch. The large hand is the hand that starts when you start the chronograph, usually by pressing the upper button, this button will also stop the hand. The other button, lower one, will reset the hands back to zero.
May 22, 2011 • Watches
Want to use larger second hand and set other to zero. have small one working now and the larger one would work if i pressed the top button on side of watch now it wont do anything if i press button dont...
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • 57helpful
    3answers
    My Tag Heuer chronograph will not reset to zero.
    Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
    How to reset the chronograph hand back to zero (12
    you can find an exper in the local shop where you buy the product and they will give you specific service
    for your questions about your product.
    In addition, i like to play world of warcraft. there is a reliable website for
    all players to get cheap wow gold with the lowest price wihit in
    10 minutes' fast delivery and you also can enjoy first class service
    for your login.
    7helpful
    3answers
    Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
    Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
    Second hand jumping
    If your model is not an automatic movement then it means your battery is too low in remaining power to support the watch.
    48helpful
    6answers
    Seiko chronograph alarm
    Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
    Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
    39helpful
    3answers
    Reset Stopwatch Hands on CL1111 ?
    Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
    1helpful
    8answers
    Sep 19, 2007 • Watches
    Top Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Watch Expert? Answer questions, earn points and help others
