Have frigidaire front loading washing and my fabric softner stopped draining out of the dispencer. What should I do.
Posted by jquillen62 on
Inestein
    New Friend:
  • 19 Answers
Remove the entire dispenser from the machine by pushing down on the catch usually rear left side. Take out the divider from the bleach and fabric softener and clean as much goo as you can get our of there using a toothpick or small screwdriver. Check the tube sections and clean completely. Test by putting it back together and slowly pouring water in the dispenser and it should fill then start draining once the level gets high enough. Stop filling and if level it should empty itself out.
You can help prevent this by diluting the softener in the dispenser without filling to the max.
Posted on Sep 18, 2010
  • jquillen62 Sep 18, 2010
    I have already taken it completely apart and scrubbed the heck out it. Top, bottom all nocks and crannies. I also crammed my arm in the washing drawer space and cleaned the dickens out of it too. After all of that I turned it to a hot water cycle and ran it through without any clothes. I thought that should have cured the problem so I did a load of clothes ..... and all be danged the softner dispenser still had all the softner in it at the end of that load. hmmmmm Got any other ideas?
  • Inestein Sep 22, 2010
    Try the extra rinse cycle and make sure you don't have to select fabric softener on the console.
    You may have a defect in the dispenser. Have you tried any diagnostic tests? Post your model number and I can look up the model and see if that helps. Make sure both supply water lines are fully on.
The fabric softner tray isn't draining
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 21, 2011 | Frigidaire GLTF1240A Front Load Washer
Fabric softener does not dispence
Just fixed the fabric softner dispenser for my wife, so I wrote a tip about it...
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 24, 2010 | Frigidaire Affinity ATF7000E Front Load...
My front load washer will not empty out the fabric softner. I have taken out the drawer & cleaned it. It will empty out the laundry soap, but not the fabric softner
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
Nov 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Fabric Softner will not drain?
That stuff tends to build up in there.. Might be clogged.. See if you can get the dispencer drawr out and clean the pathway of the softener..
Hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FABRIC SOFTNER DOES NOT DISPENCE
Check to make sure the litle cups are set in place correctly and also make sure they are not blocked with hard fabric softner. A quick test: pour water directly into the fabric sofnter cup and fill it up,IF it siphons out, you will need a new inlet valve for that unit. The inlet valve has soliniods on it for the bleach & fabric softner.
Good Luck!
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
NO FABRIC SOFTNER
The fabris dipencer hose was clug need to remove hose , clean w/ stick not so tight rinse w/ water then assemble .
Jan 09, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
