Stanley Pneu Roof Stapler Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking operators manual for stanley bostitch rn45b
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
575
Points
The piston does not retract after shooting a nail on my Bostitch RN45B roof nailer. I have replaced the drive guide which was broken. Any ideas??
  • John Trevino May 20, 2014
    When the piston does not retract at all check the rubber band around the cylinder. Remove head and pull out the cylinder, there should be a rubber band around series of small holes. When the piston retracts only part way up, check for too tight or too loose piston oring and /or obstruction in the head valve. Good luck
    Bostitch was purchased by Dewalt. Parts and information can be found at Dewalt service.
John Trevino
Level 3:
  • Stanley Master 1,420 Answers
  • Posted on Sep 19, 2010
John Trevino
Stanley Master
Level 3:
Answers
1420
Questions
Helped
1012142
Points
3200
Look here for manual and parts:http://www.bostitch.com/default.asp?TYPE=STATICLEFT&PAGE=tooldoc_results.htm&Left=left_tooldoc_results.htm&partNum=WM45B&serialNum=
The two lines of address above should be all one line in the address bar. If it does not work, go to www.bostitch.com , service parts and find wm45b. Good luck
Stanley Bostitch electric stapler model 02010 disassembly
Question moved from Larry's Computer Forum to Bostitch Staplers.
Have a read of the manual, but in general terms, these are not repairable. These days screws are often hidden under the rubber feet, but a new trends is to save on screws and build plastic catches into the case itself. They need a 'spudger' to press around the seam of the case and find where the catches are.
https://manualzz.com/doc/23446217/bostitch-office-02210-electric-and-battery-operated-stapler...
Bostitch stapler stuck
Hello, Go here to download the operators manual to help you with troubleshooting this stapler. It also will have a number for tech support so you can call for help. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Stanley Bostitch SB-1664FN will not activate at all when ptrigger is pulled. Air supply is OK- Plunges but will not fire :-o ??
Sounds like a safety mechanism not activating the trigger. If you have the manual look for the breakdown diagram and check that everything is in place on the gun. If not go here and you can get manual.
http://servicenet.bostitch.com/Products/Detail?productNumber=SB-1664FN
3helpful
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
5helpful
I am looking for an online manual for a Bostitch
http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
2answers
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
2helpful
I am looking for a manual for the Stanley Intellilaser Pro 77-500
I downloaded a manual for my Bostitch (stanley) framing nailer yesterday from their webpage. You should be able to find one somewhere on stanleys home page.
5helpful
3answers
Looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Top Stanley Tools & Hardware - Others Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
