Office Depot Ativa Wireless-G USB Network Adapter (AWGUA54) Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I try to connect to a network, so, i got to "Connect to a Network and click on my existing wireless network, but it says: " The setings saved on this computer for the network do not match the requirements of the network" and it gives a cross sign where there is supposed to show the network icon, pelase help
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Sep 18, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
Helped
23641
Points
220
  • Go to your network and sharing center
  • on the upper left hand corner, click on manage wireless networks
  • highlight your existing network and remove it
  • try to reconnect again to your existing wireless network
My wireless network connection disconnected. When I tried to reconnect (I have a secure wireless router connection), my network name wasn't listed in the list of options. I restarted my router and...
1. Directly connect to the router with an ethernet cable from your PC.
2. On the browser, enter the router's IP address
3. Log into the router
4. Navigate to router's wireless setup
5. Change the SSID to something NEW and DISTINCTIVE - do not use a default SSID
6. Make sure SSID is being broadcast - click to set the check-box if it wasn't set before
7. Save and exit the router setup then disconnect the ethernet cable
8. On your PC, View Wireless Network Connections
9. Click Network Task to Refresh network list
10. Your router with new SSID should show on the refreshed network list
11. High light your router's new SSID and click the Connect button
12. On the pop-up requesting WEP or WPA key, enter the key you had set in the router before.
tip
How to remove an Existing Wireless Profile (XP, VIsta, Win7)
When we connect to a wireless network, a "profile" is saved so that, in the future, the Wireless Network Adapter will connect automatically to the network if it is available. These profiles are saved and used by Windows even if you changed the settings on your wireless router causing connection problems. You need to delete these profiles to allow Windows to create a new one that is compatible to the new settings of the router. <br /> <br /> To delete an Existing Wireless Network Profile: <br /> In Windows XP, if you're using "Wireless Zero Configuration" to manage your wireless networking, go into the Network Connections folder ("Start &gt; Run", type ncpa.cpl and click OK), right click the Wireless Network Connection, select Properties and then the Wireless Networks tab, where you can highlight and then "Remove" an existing profile. <br /> <br /> <br /> <img src="iantechson_3.jpg" /><br /> <br /> <br /> <br /> If you're using third-party software provided with the wireless adapter, there should be a similar option to remove an existing profile. <br /> <br /> In Vista or Win7, right click "Network" (My Network Places) and select Properties. Click the link at the left to "Manage Wireless Networks" then, in the next window, highlight the "Network" to delete and click the "Remove" button. <br /> <br /> <br /> <img src="iantechson_4.jpg" /><br />
on Aug 06, 2011 • Computers & Internet
I have set up a password for my belkin wireless router and now when i connect it says limited access and the settings saved on this computer for the network do not match the requirements of the network
Hi Andrew,
This should be an easy one to fix. First, unplug power from the modem and the router for 30 seconds. Power on the modem first and wait one minute. Now power on the router and wait one more minute. This will remedy the limited access issue.
Now we'll fix the 'settings don't match' issue. Here's what's probably happening:
You had connected to your wireless network with no password previously and windows saved a connection to this network. Now, you are trying to connect with security enabled and windows is saying "hey, I know this network, but my saved connection doesn't have any security"
So.....you need to delete the existing connection to your wireless network and then re-connect to it.
In windows 7, go to control panel and click on the network and sharing centre. now click on manage wireless networks and delete the connection to your home wireles network.
Now reconnect to your wireless network and you will be asked for the password. Enter it and everything should be good.
Please let me know if this helps. I f not, get back to me and I can help some more.
Regards,
Joe
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
Open Network Connections
2.
Right-click Wireless Network Connection, and then click Properties.
3.
On the Wireless Networks tab, do one of the following:
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
2helpful
Hi, does anybody have an idea why my dell d600 and my d510 wont actually connect to a wifi network, it can detect them ok, but it just will not connect to it, i have tried new connections / ssid name /...
You need to remove all your existing preferred wireless connection from your Network and sharing Center by clicking the manage wireless networks and removing each one by right-clicking each and select remove.
In xp, open view available networks and click the change advanced settings and remove all existing preferred networks then try to connect again to the wireless network you're trying to connect.
2helpful
Wireless connection for Win 7
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
3helpful
Netgear wpn 111 on windows xp - "connection failed firewalled"
Check what security encryption is being used on the wireless network. Also, if you are using MAC filterning on the wireless network then disable it and then try connecting. Moreover follow the steps below to connect to the wireless network:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
1helpful
ROUTER INSTALLATION AND CONFIGURATION
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
for wireless:
connect a computer to the router hard-wired
for your router, open a browser and access 192.168.1.1
leave it blank for the username and admin for the password field
click wireless tab, change the Wireless Network Name (SSID):
click save settings
next click Security Mode: and choose WPA2 Personal
make a password in the WPA Shared Key: field
click save settings
on the computer, go to view available wireless network & click the wireless network name you made, connect, enter password when prompted.
good to go
Top Office Depot Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
