Depends on the printer and the computer. If you have a newer computer just go to "printer/faxes" . Make sure you printer is all plugged in and turned on and tell computer to find the computer. Many of the drivers are already on your computer and it will load the one that is necessary. If not then search the internet for a driver for the printer, and load it into the computer and all should be ok.
System Restore will allow you to select a Restore Point
(date and time) to set your system back to when it was working ok. It
does not delete any of your data, documents, music, pictures, videos or
programs (unless the program was installed after the Restore Date you
selected).
System Recovery (sometimes referred to as Factory Restore) will set your system
back to when you first purchased it. It Deletes Everything. Most
times the System Recovery does not work unless there is a recovery partition on
your hard drive created by the manufacturer. If you are trying to recover
from a set of cd's most times it does not work.
Instead of doing a System Recovery it's much easier to just Reinstall
Windows. Look on your computer for the Certificate of Authentication
(COA) Sticker. It will tell you what operating system is on your computer
and it will give you the Product Key Code (a series of 5 letters and numbers)
that you will need to activate windows. If you don't have an operating
system disk, borrow one from a neighbor, friend, relative or co-worker. Just
make sure it is the same as your COA Sticker's operating system or it will
never activate. Also make sure you get the COA Product Key Code for the
disk you borrow because sometimes the system will ask for the one that is on
your system and sometimes it will ask for the one from the installation disk.
selected).
