Question about Watches
I have an aquatech watch and don't know how to set it.
Posted by breshaw1922 on
Janelle Schoonover
  • 842 Answers
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Posted on Sep 18, 2010
    I have a high end aquatech the band has broken and cant find the aquatech company to order another band
    I would check Spiedel, they make a lot of replacement bands. Measure your existing band and you can likely find a replacement.
    Aug 08, 2015 | Watches
    Have a Aquasport 3ATM watch(red). Could
    Was not able to find an actual manual for the Aqua Sport watches but what able to find a posting on How to Set an Aquatech Watch. Perhpas the following will be of assistance:
    http://www.ehow.com/how_4587869_set-aquatech-watch.html
    If this does not help, are you able to provide any more infmration about the manufacturer and the specific model you have.
    Apr 16, 2011 | Watches
    How do I set watch from military time to a.m./p.m.
    mcdevito75 here, I'm sure you can type in search from your home page, Aquatech watch instructions This should help.
    Jul 12, 2010 | Watches
    I don find instructions on line.
    Try the instructions for the Aquatech watch at
    It looks similar to your watch.
    Mar 04, 2009 | Columbia All Sport Digital watch
    CAN'T SET TIME
    I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
    My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
    Feb 28, 2009 | Oakley GMT OAK0531 Wrist Watch
    Athletic works watch
    I just bought an Athletic Works watch at WalMart that is identical to the Aquatech watch I bought there some years ago. My band got hard and cracked so I needed to buy a new one as the band is not available. For $9 the entire watch is probably cheaper than a band. I used the instructions from my Aquatech to set the stuff on the AW. I found the instructions on the internet. Here is one site that has them.
    Give it a try.
    Clem S
    Sep 23, 2008 | Watches
    Aquatech watch
    press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
    press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
    hope this helps
    jeff
    Jul 23, 2008 | Watches
    Aspen watch
    Setting my Aspen Digital Watch
    Button designations:
    (NITEGLOW) B C (START/STOP)
    10:47
    (MODE) A D (SPLIT/RESET)
    To Set Time, Date and Day:
    Press A 3 times; Seconds Flash; Set to 00 with C
    Press D; Minute Flashes; Set Minutes with C
    Press D; Hour Flashes; Set Hours with C
    Press D; Date Flashes; Set Date with C
    Press D; Month Flashes; Set Month with C
    Press D; Day Flashes; Set Day with C
    Press A to Quit
    To Set Alarm Time:
    Press A 2 times; Hour Flashes; Set Hour with C
    Press D; Minutes Flash; Set Minute with C
    Press A to Quit
    To Set Alarm ON or OFF:
    Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
    Operation:
    Hold C to see Month and Day.
    Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
    Mar 27, 2008 | JCPenney Armitron Sport Link Bracelet...
    Aquatech
    Press the "mode" button in and hold it for a few seconds, when the display flashes use the "start/stop" button to advance and "lap/reset" to select the section you want to change. When finished just press "mode" again.
    Oct 25, 2007 | Watches
    Watches Logo
    1,225 people viewed this question
    Top Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
