Question about Grundig YB 400PE AM/FM/SW Radio
How to set memory - Grundig YB 400PE AM/FM/SW Radio
Posted by jsalkin9 on
Stelios
    President:
  • 1,851 Answers
Here is a specific example. To store
BBC's evening frequency to North America, 5975 kilohertz, into
memory 32, do the following:
1. Press 5975
2. Immediately press the FREQU./METER button
3. Press 3 2
4. Immediately press the STORE button. If the display
flashes, it means that a frequency is already stored into
this memory. To overwrite it, immediately press STORE
again. If you do not want to overwrite it, start over and
use a different memory.
In case you need further settings here is the link for the user manual.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 18, 2010
How do I get more memory for my bernina 730?
Resetting factory settings in some models will only reset the settings of the machine and does not effect the stitch memory.
to clear the stored stitches from memory try the following.
press «clr/del» and left / right arrow
button at the same time
• release both buttons
• leave Memory by pressing the
Left / right button
• Memory is now completely
deleted
You can hold a max of 30 stitches in memory on most models.
Nov 20, 2014 | Bernina Sewing Machines
Set memory card as default storage
Go to bluetooth settings and set phone settings to music memory and make it go to memory card not to phone memory
May 06, 2013 | Nokia C3-00
Memory phone full
hi
sometimes the ringtones from mthe card will go to the phone memory but this is not the problem.
the ring tones are small in size.
each program have to be set card memory or phone memory.
the picture or video is the biggest memory "eating"
i think this is your broblem you have to move all your picture and videos to the card from the phone and than set the phone to use the card for picture and video.
http://www.rylwy.com/
Jul 19, 2012 | Samsung Corby 2 GT S3850
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
Jun 14, 2010 | Omron Healthcare Omron Hem-712c 712 Blood...
In my Nokia3110c phone empty phone memory but not adding setting
make sure you downloads and bluetooth are set to memory card and not phone memory
May 07, 2010 | Nokia 3110 Cellular Phone
I want to get the default memory as for memory card
Hello Saurabh,
Do you mean you want to set your memory card as your N73's default memory to store data? Well, here's how:
For Videos, select Options > Settings >> Memory in use — it define the default memory store: device memory or memory card (if inserted).
For Messages, select Message > Options > Settings >> Memory in use
For other settings, you may want to check out the manual here:
http://nds2.nokia.com/files/support/apac/phones/guides/Nokia_N73_APAC_UG_en.pdf
Hope this helps.
Oct 30, 2009 | Nokia N73 Cellular Phone
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
Memory card settings
go to settings-memory settings-default memory-bluetooth-memory card
Jan 02, 2009 | Samsung J700 Cellular Phone
Nokia memory problem.
format your memory! virus in your memory card!
Jul 06, 2008 | Nokia 6680 Cellular Phone
Grundig YB 400PE AM/FM/SW Radio Logo
144 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
