Ceejay a 9 flash error code usually means a brake fault. But a brake fault will not cause the chair not to power up. Check all your connections especially where the cable comes out the back of the joystick and where that same cable plugs into the cable to the controller. Sometimes the switch on the joystick fails to make good contact with the circuit board in the joystick and you can try pushing it in different spots to see if will come on. Also check the circuit breaker to make sure it hasn't tripped. If you have a digital voltmeter you can set it on 200 volts dc and plug the leads into the two outter holes on the charger port located under the front of the joystick. You should be reading the battery voltage and fully charged get 25-27 volts. If you don't get any reading then there is a problem in the cable or joystick or power from the batteries. You didn't say if Medicare paid for your chair. If they did they will pay for most of the repair costs. If they did you can contact Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have a tech come out to check your chair. Hope this helps you
Testimonial: "Lennieg2000, you ARE the Guru. The info on the connection to the joystick was DEAD ON! it was came loose. Thanks so much for sharing your knowledge!"
9 flashes on the MK5 SPJ+ w/ACC joystick is a communication fault. You will want to have the cable that plugs into your joystick checked out by a technician. The reason I suggest a tech is because they will have a replacement cable to fix the problem. I work on Invacare Pronto M51/M61's on a daily basis and with the swing-away joystick the cable wears out from swinging the joystick to the side to drive up to a table.
I have a M6 that doesn't work. When you first turn the power on the little led light flashes Red, followed by three green flashes. Can anyone help....
Phil....
