Your water leak can come from 3 areas:
1) drain hose on back of washer is coming off / splitting / getting loose
2) water pump is leaking (cracked?) or has a gasket that has deteriorated.
3) hose between tub and water pump has come off / split / became loose.
Since your washer isn't able to hold water, it makes it easy to remove the clothes, and lean the washer forward to see what is going on. Most washers' mechanicals can be acessed from either the bottom, or from the back via access panel. The water leaks are generally a pretty easy repair.
This is a good question; what brand of washer machine do you have?
Is it front or top load?
Leaks water from the front door, from where you load the soap or from the back or bottom?
If it is from the front door it could be the gasket, if it is from where you load the soap it's the same soap clogging the fill hose, if it is from the back it could be the hoses or the fill valve, if it is a top load and you see the water liking from the side or bottom, then, if it is from the side the fill hose is your problem if it is from the bottom then it could be the seal from the drum or just a leaking pump.
Please be more specific
