Question about HTC Touch P3450 Smartphone
How can i open htc touch cover both panal - HTC Touch P3450 Smartphone
Posted by atulmahamuni on
Anonymous
    Problem Solver:
  • 7 Answers
If its the back panel, then you can do so by the steps I'm listing below with three images for each of the steps:
1. Hold the phone so that the back panel faces you and the bottom of the phone is towards your right hand and push with your right thumb while holding phone with your left hand to maintain balance. Shown in 01.jpg here.
2. When you push, the back panel will move a few millimeters and stop as shown in the next image with the red highlight.
3. And now you can successfully removehow can i open htc touch cover both panal - ashvyn_venks_1.jpggratulations.
Posted on Nov 24, 2010
  • Anonymous Nov 24, 2010
    If its the front panel, then after opening the back panel, there will be four screws. Opening those will open the front panel. But I won't recommend that as the alignment of the touchscreen gets disturbed.
My htc in danish .. i need it in english ??
Hi there!
Changing the language of your HTC touch is really easy. Just follow this simple steps:
  1. Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings.
  2. Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
  3. Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose
If you need more information about your HTC Touch, just open this website: HTC Touch User Manual.
Hope this helps.
Jun 03, 2011 | HTC Touch Cellular Phone
Hi my htc touch viva is seized up. what can I do if nothing moves on the screen?
try restarting it.... if still frozen ... open the back cover and remove the battery... replace it after 10 minutes.... start the phone.. if all is ok then fine else you can soft reset the phone ...if still not working then hard reset the phone...before you try anything back up your phone....check the manual to know how.
Aug 08, 2010 | HTC Touch Viva Cell Phone
HTC getting hanged again & again
SAVE UR IMPORTANT DATA FROM PHONE & THEN RESET THE PHONE FROM COVER UR BACK COVER FROM BATTERY.
UR PHONE WILL BECOME IN FRESH CONDITION.
Jan 31, 2010 | HTC Touch P3450 Smartphone
During spin cycle the washer allows water to enter the machine. If I shut the water during this cycle it spins out fine but when the cycle reaches the off position it doesn't really shut off. Sounds like...
open the door on the washer,in the middle rear just above the tub you will see the shute were the water comes in to the washer,make sure it is connected to the back panal,if is not than you will nead to remove the washer top door and cover assemble,there is a panal between the dryer and the washer,at the top of the panal on each side you will see a screw,remove them and remove the panal,at the back of the cover on each side you will see a clip with a 5/16 screw in it,remove the screws and slide the cover forward about 1 ",next lift the frount of the cover and on the right side you will see the door switch conneter,unhook the conneter and remove the cover,next you can see the water inlet shute,if is broken than replace it and hook it up to the back panal,next replace cover and panal and run a test run.
Jan 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
My htc bluetooth is not working
Hay hello open your mobile back cover and at upper postion there is a reset button click that button with your stick and leave your mobile for tow ours your blue tooth will be start working
Aug 18, 2009 | HTC Touch Viva Cell Phone
Htc touch pro slide out keyboard not working
if the phone is less than 1 year old then yes it should
Aug 02, 2009 | HTC Touch Pro Smartphone
Touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Jul 07, 2009 | HTC Touch Cellular Phone
Where do i find the device code on a HTC Touch Diamond?
By device code if you mean serial number, pop open the back cover (push it up, when the USB port is facing down, I did it the wrong way the first time, yeah its embarrassing haha). Then take out the battery, the serial number should be located there.
If you mean something else, like rom version, hardware version, etc or Model number, those can be found in start>settings>system>device information.
Dec 01, 2008 | HTC Touch Diamond Smartphone
Cracked front cover on HTC Touch
HTC will help you with this because it is so new. However if you dropped it (etc.) and if apple doesn't replace it for you, You can get the part at HTC Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Feb 16, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
202 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Rob Woolcock
Rob Woolcock
Marvin
Marvin
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
