Question about Compaq Presario 700 470024-192 Notebook
My compaq presario c700 screen is on but only black show and if you move it back and forth you can see the password page but its all broken up and has yellow lines running through it. what causes this and how can i fix it. i just changed the bottom case because the corner screws were all broken
Posted by ejelectrical on
Larry Ng
  • Compaq Master
  • 5,982 Answers
LCD is toasted
rip
or its cable bad,.rare.
Posted on Jan 28, 2018
  • Larry Ng
    Larry Ng Jan 30, 2018
    advice get rid of this PC
    go to goodwill(tm) stores.
    pick out a vastly newer PC that was not droopped like yours was(or hit)
    for small cash
    bet 2010 or newer PC, and win
    find one even with a W7 service tag on it.
    from HP.
    win all the way !
    all pCs with square screens have zero value, and have no future. (4:5)
5 Related Answers
peepnklown
Frank
  • 175 Answers
SOURCE: Compaq Presario 5000 start up problem
Follow the instructions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=96382&prodTypeId=12454&prodSeriesId=96382&objectID=bph07173
Posted on Nov 11, 2007
Anonymous
SOURCE: compaq presario c700 laptop
ALL THE DRIVERS U'LL EVER NEED FOR COMPAQ PRESARIO C700
(VGA) Driver:
http://downloadmirror.intel.com/13300/a08/win2k_xp1429.exe
Chipset Driver:
http://downloadmirror.intel.com/13499/a08/infinst_autol.exe
Wireless LAN Driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34152.exe
ALPS Touchpad Pointing Device Driver:
ftp://ftp.hp.com/pub/softpaq/sp31001-31500/sp31075.exe
5 in 1 card reader driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33604.exe
HP Quick Launch Buttons
ftp://ftp.hp.com/pub/softlib/software8/COL18360/ch-47422-1/sp33258.exe
LAN Driver
ftp://ftp.hp.com/pub/softpaq/sp30501-31000/sp30580.exe
To install audio / modem drivers, first download and install Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp32646):
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp36090.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
This will create a swsetup folder in C drive ("C:\sp36090")
Installing this driver may result in an error. But continue with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\sp36090 folder and select the .inf file (CpV30D5a) and click open and Continue with the onscreen instructions.
Conexant CX20548 Modem Driver for Microsoft Windows XP (sp36089.exe) (UAA Driver needed)
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36089.exe
Download and install Conexant modem driver (sp36089). This will give error message and also will create a folder C:\swsetup\sp36089 which contains extracted driver files.
The same method which is used for installing audio driver needs to be followed for modem.
Posted on Feb 24, 2008
myob247
Georgia B
  • 1342 Answers
Use this link to find your specific model of the Presario c700
Posted on Apr 05, 2008
ABRsvcs
  • 4234 Answers
SOURCE: broken headphone socket on compaq presario c700
It can be replaced as it is most likely a standard part. The problem is that 1) it is a surface mounted socket and 2) the entire laptop must be dis-assembled to get to it. This is not a repair I would recommend to a novice. Ask around for someone that can work on surface mounted parts and see how much for the repair. The part should not be more than $2-$4.
Dan
Posted on Jun 04, 2008
Deeps .
  • 1257 Answers
SOURCE: Need Sound Card Driver (Compaq Presario C700)
Installing only audio drivers will give you error "DRIVER INSTALLATION FAILED. COULD NOT FIND MEDIA DEVICE FOR THIS DRIVER" .so to solve this problem first you have to download microsoft universal audio driver and then install audio drivers
Audio Drivers
link 1 :microsoft universal audio
ftp://ftp.compaq.com/pub/softpaq/sp32501-33000/sp32646.exe
After installing microsoft universal audio driver you can install conexant high definition audio..........that's it
_____________________________________________________
If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
How to reset BIOS setup password?
Well, I haven't worked on a Compaq for a few years but they're one of the models that respond to having the CMOS battery removed.
Basically, remove battery, find location of CMOS battery (usually under memory cover or HDD cover) and disconnect or pull it out for 30 minutes and you should be back to factory defaults.
Apr 25, 2015 | Compaq Computers & Internet
How to repair speakers for compaq presio c700
The first thing you do is go to HP Support > Compaq Presario C700 Notebook PC > Main Support page > Manuals > Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3559331&
HP G7000 Notebook PC and Compaq Presario C700 Notebook PC -
Maintenance and Service Guide
http://www.hp.com/ctg/Manual/c01301275.pdf
Then go to Page 13 - Illustrated Parts Catalog.
Then Computer Major Components - Page 14, to end on Page 16;
6) Speakers - 454946-001
It's an HP part number so type - HP 454946-001 in your browser search bar, and press the Enter key,
http://www.ambry.com/454946-001.html
http://www.sparepartswarehouse.com/Compaq,Laptop,Part,454946001.aspx
http://www.ioffer.com/i/hp-compaq-presario-c700-c717nr-speakers-set-454946-001-527108348
Regards,
joecoolvette
Dec 21, 2012 | Compaq Presario C700 Series Laptop...
HOW TO BREAK ADMINISTRATOR PASSWORD TO Compaq Presario CQ57-339WM Notebook PC
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • There is a free boot CD called Hirens. This one command prompt only. http://www.hirensbootcd.org/
Oct 21, 2012 | Computers & Internet
Manual for compaq c700
dear,
you can download the service and maintenance manual from the below link
if you want user manual then catch it from here.
http://www.manualowl.com/p/Compaq/Presario-C700/Manual/64921
from this link, you can download each manual in details and separately.
best of luck!
Apr 18, 2012 | Compaq Presario C700 Series Laptop...
Compaq presario c700 laptop
i want to all drivers for compaq presario C700 madel, please hurry uppppppppppppp
Aug 19, 2008 | Compaq Presario 700 470024-192 Notebook
Missing drive
Use system restore to set computer earlier date that was working fine. If there is a missing driver by symptoms please go to support.hp.com or
http://h10061.www1.hp.com/ccsearch/search?method=mainQuery&qry=driver%5D&pname=Compaq+Presario+C700+CTO+Notebook+PC&ptype=consumer&stype=pn&spname=Compaq+Presario+C700+CTO+Notebook+PC&spid=3559331&productBigSeriesOid=3466273&pid=3559276&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001&lang=en&ctry=us&dlc=en&mode=lz&uqry=&pname_desc=Compaq+Presario+C700+CTO+Notebook+PC
For further assistance please post more.
Good Luck
Jun 16, 2008 | Compaq Presario 700 470024-192 Notebook
Audio and Wirless driver for compaq c700, model - C765TU
I'm looking for a Wirless driver for compaq c700, model - C765TU. Pls help
Thank you
May 25, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
126 people viewed this question
Top Compaq Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
