Jenn-Air JED8430 Electric Cooktop Logo
Posted on May 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one of the dials to switch a burner on the red light around the dial glows as normal but the burner doesn't glow or get warm as it usually should. This happened to all 4 burners at the same time. The blower extractor fan still works. I have checked the fuses and they seem to be fine. Any suggestions would be appreciated? Many thanks in advance.
Marvin
Level 3:
Top Expert:
  • Jenn-Air Master 85,242 Answers
  • Posted on May 03, 2017
Marvin
Jenn-Air Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29057686
Points
266281
For free help and parts the best website for this type of home appliance is at the link below.
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Mar 04, 2007
SOURCE: Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Anonymous
  • 473 Answers
  • Posted on Oct 19, 2007
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Anonymous
  • 1314 Answers
  • Posted on Dec 30, 2007
SOURCE: jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Anonymous
  • Posted on Dec 12, 2008
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
Anonymous
  • Posted on Apr 15, 2009
SOURCE: Jenn-Air Cooktop replacement needed
You can get a new cooktop surface from Maytag/Jennair for $229. It is a pain however to replace it. Where is the crack in your cooktop and does that crack pass directly through a heating element? If not, then you may be able to repair it. I broke the corner off mine, and then dropped the piece (now 5 pieces). I was able to bond them back together and you really can't tell it was ever broken. But, it takes some work.
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
2helpful
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
2answers
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Burners are not fully heating out to the end
Either the elements are going out or the controlls for the burners are getting croded contacts. Best bet would be to replace both and go for another 7 years :-)
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
