Cobra 29 LTD CB Radio Logo
Posted on Sep 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to put talkback on my cb myself. - Cobra 29 LTD CB Radio
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 184 Answers
  • Posted on Sep 18, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
184
Questions
Helped
92922
Points
320
Hi Overton2525,
I used to install all these talkback and sound-effect devices in radios for the truckers, and most were so elaborate, that I did it in kit form. You must be pretty handy with soldering, so here we go with a bold little adventure. CB Radio Magazine has a nice inexpensive project that won't take very long to install.
Here's the link to their pages:
http://www.cbradiomagazine.com/April%202007/Adding%20talkback%20to%20your%20radio.htm
Your radio meets all the requirements for this project. Let me know how this Mod works out for you. Thanks.
Regards, Bill
How do I put talkback into a Dx33?
it can be done but it is a long process . check out www.cbtricks.com they have the information you need about talk back . if what they have isn't what you want you may have to google it for the information you want.
tip
Galaxy DX 959 CB radio no transmit or talkback
Hi, I have a problem with this CB radio. The PA works good but after installing the MOSFET kit as mentioned here http://cgi.ebay.com/DUAL-POWER-TRANSISTOR-MOD-KIT-GALAXY-949-959_W0QQitemZ190256621565QQcmdZViewItem?hash=item190256621565&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 it wont transmit and I cant hear myself on talkback nor do I hear the roger beep. The PA amp works though.
1helpful
I have the ROADPRO RPPS-550 4 Noise Cancelling CB Extension Speaker with Talkback, why is there 2 male plugs and where do they get plugged in at. One obviously to the CB radio. The other ???
Both should go to the CB radio. One would be for "audio out" from the radio, the other should be for "audio in" to the radio to handle the "Talkback" feature. I doubt that most CB radios will support this. Your best bet is to determine which plug provides output to the speaker (so you have better audio output from your CB - if that's actually possible) and disregard the 2nd plug if your radio doesn't support it. Hope this helps.
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
How to make a talk back with a external speaker for a cb radio
take off top and bottom covers.look for the ext and pa speaker in putsolder a 33 ohm resister over the pos and neg of the plugins,one lead for each and now you have talkback.
1helpful
3answers
No talkback
Remove D80 to achieve talkback, or put on switch. - www.killercatradio.com
Want to get talkback in a cobra 29
When you key up the mic ungrounds the speaker so you don't hear anything through it, so to get talkback you're putting a 100 ohm 1, or 2 watt resistor between the switched side of the speaker and ground, now when unkeyed the mic grounds the speaker as usual, but when you key the resistor allows a bit of audio from the audio amplifier, not decoded RF, to still get through. I think the pa/ext spkr. jacks are a convenient place to connect it. You may decide to control talkback by running the circut thru a switch like brite / dim switch . Want less talkback, use more resistance, 150 ohm . Too much talkback can become feedback . I hope this helps, J
Disable talkback
one turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
2helpful
2answers
I want talkback on my cobra 29ltd classic radio how do i do this myself
Open the case on your radio. Solder a 100 ohm resistor between the pa jack and ext speaker jack. You can add a switch if you like to turn it on and off. The lower the resistance, the louder the talkback.
WANT TO ADD TALKBACK IN A RADIO
A 200 ohm 1-watt resistor across pins 1 & 4 of the mic jack will make some talkback. More or less resistance will make less or more talkback. Note the association of less and more.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
