Does your freezer seem to be reaching around zero degrees. Second does your freezer have its condensing coil under it or on the back and is it clean. If the coils are not clean it can not disapate its heat effectively and will continue to run. If the coils are clean and the door seal is in good shape doesnt have to be perfect your unit may be low on freon. When a unit first gets low it will run all the time and actually get colder for a while then it will start loosing its ability to cool at all. The ice around the door can be caused because of air leaking in or just excess moisture in the cabinet due to a lot of new items added. I hope this helps
