Question about D-Link AirPlus DI-614+ Wireless Router
How can i turn on wlan on my router? would this be the reason laptops will not connect to it?
Posted by jenn_pink24 on
Anonymous
    Scholar:
  • 91 Answers
By default, the WLAN on your router is enabled. This is the setting that will give wireless computers wireless internet connection.
Posted on Sep 18, 2010
2helpful
2answers
Where is the WLAN switch on my Dell 5500 Latitude? How do I turn it back on?
Press the key <FN> and then <F2>. This will enable wireless connections.
1helpful
Why does my WGT624 keep loosing connection. I would be on the Internet and for some reason, I would loose connection to the Internet. I have a Dell Inspiron...1521 computer.
In my case too this happened initially with my lenovo y410 laptop with netgeat router. In laptops if th ewireless network is set with "public" profile then the connection is sometimes dropped by the driver. If you or only a few persons are the only user(s) of your router and your WLAN is securely encrypted, then you can change the wireless settings of your laptop to be in "private" network, which will solve your problem.
Have labtop computer but for somereason computer
The owners manual should tell you how to do this but below is a summary.
Connect to your router via the cable connection by typing in the ip address of the router. Note the SSID, Password and security settings. Also make sure WLAN is transmitting via WiFi.
Disconnect pc/router cable.
Activate your WLAN at the pc
Make sure you can see your SSID from your Laptop.
Make the connection by clicking on your SSID and enter the required password and security settings.
Can't turn on wireless on computer
which toshiba satellite pro ?
is wireless on at the laptop?
sometimes a combination: Button FN & F1-F12
try to connect router via ethernetcable:
inside routerconfiguration enable wlan
sometimes routers have a switch outside to enable/disable Wlan
is there a WLAN-LED at the router?
1helpful
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
1helpful
Wireless card in E1505 Dell not finding networks in range
The 1390 WLAN Minicard may not be configured to communicate with your wireless router.
Check the wireless router settings, (check the wireless settings on your other computer) and configure the 1390 WLAN with the same settings eg. SSID, WEP/WAP encryption, etc.
Is MAC address filtering enabled on your wireless router, if so add the MAC address of the 1390 WLAN to the MAC address list in the wireless router.
Check the TCP/IP properties of the 1390 WLAN card the Internet protocol should not have a fixed IP address, set it to Obtain an IP address automatically including the DNS.
Use the Ipconfig command to see the IP configuration of the network cards.
Use the Ping command to see if you can communicate with wireless router.
WLAN does not work
Can you try and reset the router once. I guess that should help . There should be a reset button behind the router and the reset procedure should be present in the manual
Notebook won't connect to network
1) Verify if Wi-Fi WLAN interface of your notebook is OK.
1a) Check whether HW switch is ON and the wireless system service is running.
1b) Switch on the WLAN Access Point (router) SSID broadcasting.
1c) Scan WLAN networks by the notebook. Can you see your home WLAN? If not, there is HW or SW problem in your wireless adapter probably. If WLAN is visible, continue by next steps.
2) Remove all WLAN security on both sides (AP and notebook): Authentication = none/open, encrytption = none.
3) Activate DHCP server in the router and set the dynamic IP assigning on WLAN notebook interface.
4) Select your home WLAN SSID in the list and try to connect.
5) Wait and check status. Is WLAN connected? Does obtain the notebook an IP address?
6) In success case set the WLAN security.
My laptop and the router won't stay connected.
This is common with many manf. of routers. I have had the same issue. Are you running WEP? If so that's probably the culprit. For some reason, IEEE allowed more than one hash routine to get out there in the field, so sometimes if you have varying brands end-to-end, they can generate the hash-to-value a slight bit differently. So either a)Disable WEP b)Get netgear PCMCIA on laptop c)Move closer or change string in your WEP key to ONLY include 0-9 a-z d)Get a repeater. (Either netgear or brand of laptop WLAN NIC) Hope this helps. (I ended up disabling WEP as MAC filter and SSID turned off are sufficient enough for home use security.)
Open Questions:
D-Link AirPlus DI-614+ Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
