Question about AudioSource Amp Four 2-Channel Amplifier
I have 4 speaker wires, black green red white speaker left + speaker right + speaker left - speaker right - which cable goes where?
Posted by silvio308 on
Anonymous
    New Friend:
  • 35 Answers
4 speaker wires, black, green, red, white ;speaker left +speaker right +speaker left -speaker right. First see what pair of speaker wires go to left the channel of the amplifier. One of each speaker must be connected to each amplifierĀ“s channel, no matter of colors of the wires. Two wires for each speaker to each channel of the amplifier (rear panel + and -). Then you will have 4 wires connected to 2 stereo channels of your amplifier. Two wires for each speaker.
Posted on Sep 18, 2010
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
May 18, 2014 | Kenwood KDC-MP538U Car CD/ MP3 Player
I need to know how to hook up an alpine CDA-9833 stereo into a 1993 dodge dakota without a wiring harness i just want to hook the wires together and i dont know which wire goes to the other all the colors...
Please let me know if you have any questions, and thanks for using FixYa.
1993 Dodge Dakota CDA-9833
Car Radio Battery Constant 12v+ Wire: Red yellow
Car Radio Accessory Switched 12v+ Wire: Red/White red
Car Radio Ground Wire: Black black
Car Stereo Dimmer Wire: Orange (tape this wire off) none
Left Front Speaker Positive Wire (+): Blue/White white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Purple gray
Right Front Speaker Negative Wire (-): Green gray/black
Left Rear Speaker Positive Wire (+): Black/Yellow green
Left Rear Speaker Negative Wire (-): Gray green/black
Right Rear Speaker Positive Wire (+): Blue/White purple
Right Rear Speaker Negative Wire (-): Blue/Orange purple/black
May 09, 2011 | Alpine Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
I need the diagram for the audio cables
do u mean the radio connector? if so here it is.
Radio Dimmer Wire: n/a
Front Speaker Size and Location: 6 1/2′ Doors
Rear Speaker Size and Location: 6′ x 9′ Rear Deck
Sep 16, 2009 | 1997 Honda Civic
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Jul 25, 2009 | Kenwood KDC-X492 Car CD/ MP3 Player
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Front Speakers Size: 6 1/2′
Rear Speakers Size: 6 1/2′
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
AudioSource Amp Four 2-Channel Amplifier Logo
270 people viewed this question
Top AudioSource Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
