Question about Woods Upright Freezer V1613RW3
Need Freezer gasket for 20 cubic foot freezer upright Model #WFF20Z
Posted by jackiemt on
Anonymous
    Scholar:
  • 113 Answers
I would suggest you check with a local appliance parts warehouse. They will also have a service manual that you can purchase that will guide you.
Posted on Sep 22, 2010
What is weight of kenmore freezer model 25320402002?
For 5-foot-tall units: A 32 refrigerator or freezer weighs about 150 pounds and takes up 38 cubic feet. A 32-inch refrigerator or freezer weighs about 200 pounds and takes up 44 cubic feet.
Jul 05, 2018 | Kenmore Freezers
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
What size is a frigidaire freezer mfu17f3gw6 ?
Good Afternoon Claus, that's a great question!
Your Frigidaire freezer (MFU17F3GW6) has a total capacity of 17.0 cubic foot. I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Jul 12, 2014 | Frigidaire Freezer Refrigeration White...
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Jun 27, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Woods Upright Freezer V1613RW3 Logo
189 people viewed this question
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
