Question about HP Photosmart C8180 InkJet Printer
HP PHOTOSMART C7280 ALL IN ONE ERROR 0C05D1281
Posted by latina70288 on
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: I cannot print C5 envelopes on HP C7280
In page setup manage custom paper sizes. Enter the size of the envelope and save it. In print dialogue box you can find the C5 envelop. Paper size: defined by driver. This should work
Posted on May 08, 2009
Anonymous
  • 54 Answers
SOURCE: HP PHOTOSMART C7280 ERROR 0xc18a0001
Follow the steps carefully from the front panel of the All-in-One.
1. Get the unit into the “Support Menu” by following the steps given below.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Now Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Now the Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11.Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Sep 12, 2009
Anonymous
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
Anonymous
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
Anonymous
  • 214 Answers
SOURCE: HP photosmart C7280 ink system failure 0xc05d0281
Go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&rule=11380&product=1153494&key=null
Posted on Nov 04, 2010
Oxc18a0206 hp photosmart c7280
Unplug power cord from printer and electrical outlet wait 30 seconds and hold in help and OK buttons while reconnecting power cord. continue holding buttons until screen turns black turn printer on and continue this helped me.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 13, 2013 | HP Photosmart C7280 Printer
HP C7280 printer: "Pump motor stalled" error
This means there's a failure in your printer's pump motor.
If you are still under warranty, contact HP's Customer Service here : http://welcome.hp.com/country/us/en/wwcontact_us.html
If not, you can try your local computer store for a check-up but they'll probably suggest a new printer.
Hope this helped.
Please rate :)
Mar 04, 2011 | HP Photosmart C7280 Printer
HP Photosmart c7280 all in one can't be found
Assuming its all connected and powered up, try re-installing the drivers.
Jul 21, 2010 | HP Office Equipment & Supplies
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Sep 23, 2009 | HP Photosmart C7280 Printer
HP Photosmart C8180 InkJet Printer Logo
90 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
