Question about Stoves 720EF Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
Posted by ogowen on
Malcolm Parsons
  • 250 Answers
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Posted on Oct 30, 2010
IN MY DOUBLE OVEN BOSH HBM 13B2551B THE TOP OVEN WORKING,BUT BOTTOM OVEN DOESNT WORKING
Look for any burned or discoloration on the bottom bake element. Did you try the broil on the lower oven? If neither is working you may have a board or touchpad issue.
Nov 23, 2014 | Stoves 720EF Electric Double Oven
Stoves 720ef bottom door not touching seal at top
Try adjusting the hinges also check magnetic seals on door itself as well.
Feb 22, 2013 | Stoves 720EF Electric Double Oven
Our top oven inner door glass for the model 720EF shattered and we need a new one. The number is 059040415.D you sell such a thing and if so how much?
Try espares. If the part is not listed, there is a section where you can leave your requirements and they will get back to you.
Apr 05, 2011 | Stoves 720EF Electric Double Oven
Having taken the oven out to fix a problem with the hob (720EF double oven and grill), reinstalled the oven and powered –up, the clock won’t come on and stay on, the oven and hob appear to work! Any...
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
I want to remove my fan unit from a stoves 720ef 1999 model
You have to remove the entire oven unit from the kitchen carcass. Once you have done this, you will need to take off the top and rear panels to gain access to the items you want.
There are normally screws holding the oven in place and a pair of these may be seen once the top oven door is down. They are located near the top of the opening on either side.
Dec 28, 2010 | Stoves 720EF Electric Double Oven
Can i slow cook in my oven, does it have aslow cook facility i have lost my manual, if it does please explain what to do. thanks
No, there is no slow cook. The bottom oven works as a normal fan assisted oven and the top oven relies on elements concealed in the floor. The top oven takes a long time to warm up.
Oct 30, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Stoves 720ef electric double oven not working
According to the circuit diagram on page 31 of the handbook, power for the ovens passes through the clock. The power feed is direct for the actual clock but via a seperate Thermal Cutout for both the top and bottom ovens. I think it is highly unlikely that both Thermal Cutouts have failed at the same time. I would try turning the power off totally to the oven for a while and then turning it back on, set the time and ensure the oven is in manual mode. As the top and bottom ovens have seperate controls after the Programmer and both are not working, it has to be the programmer that is not extending the power through to the rest of the oven.
Nov 11, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
277 people viewed this question
Top Stoves Ovens Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Stoves Oven Expert? Answer questions, earn points and help others
