SOURCE: Cannon MX310 - Fax - Waiting for report
I had the same problem.
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
SOURCE: We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It
is because your INK Level is Low and your have set "Fax Setting ->
report will not be printed out due to ink level is low.
Solution:
Configure
ink to ON", and the report will be printed out immediately, the message
disappear.
SOURCE: HP 1319f MFP reports
This error does not always refer to a fax being missed. If a telephone
call is made to a fax by mistake and the caller hangs up, the error on
the display will read 'No fax detected
Or follow the instructions listed here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01756193&tmp_track_link=ot_recdoc/c01756216/en_us/c01756193/loc:4&lc=en&dlc=en&cc=us&product=3547188#NoFaxDetected_c01756193
SOURCE: Incoming faxes do not print, fax report reads
First, does the machine print normally from a computer or when making copies?
If so, then most probably you have enabled a private receive fax mode. In this mode, faxes are not printed immediately upon receipt (to prevent unauthorized people to read them), but are stored in memory, waiting for an authorized person to come and print them, providing a PIN (password).
To print the faxes stored in memory, do the following:
- press FaxMenu
- using arrow buttons select "receive"
- press OK
- using arrow buttons select "print faxes"
- press OK
- using the alphanumeric keypad enter the PIN/password and press OK
THe previously received faxes should print..
SOmeone must have turned this option on, so ask that person what he/she entered as the PIN.
