SOURCE: siemens microwave oven HB86k.70b
I have the same problem, have you found out the cause?
Regards
SOURCE: Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
SOURCE: trying to unscrew bulb cover in a neff oven
Hi, DO NOT use WD40. Take a small towel or a rubber pad and grasp the lens with the palm of your hand. Turn it counter clockwise to release it.
It is very thick glass so, it should not break.
You might try to tighten it first. Sometimes a little nudge to tighten it will free it up.
I hope this helps you.
Please let me know if I can assist you further.
Vic
SOURCE: Pleace HELP!!! How do I
You can set the timer on a range slow cooker to automatically
switch to a warming setting when you estimate foods will finish
cooking. The programmable features allow you to leave food stewing at
home while you are out of the house, freeing up your day.
Set the timer
on a range slow cooker to let the kitchen appliance do all the
work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it
with the lid. At least a quarter of the insert should be filled with
liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control
panel in the front of the appliance. This will turn on the slow cooker
to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic
control panel to add hours to the timer which will show a total time in
hours with a red digital display. Continue to press the button until
the display indicates the desired cook time in one-hour increments up
to 10 hours.
The cooker will automatically adjust the temperature
setting based on the amount of time you programmed on the timer.
Cooking times of six hours or less automatically start on "High" heat
and times of seven hours or more will start on "Low" heat.
A small
indicator light will come on below the word to tell you the cooking
temperature.
thank and thanks for using fixya.
SOURCE: I need an instruction manual
Andy -
Download for free from here in PDF format:
http://www.russellhobbs.co.uk/pdf/product_139_13824-10.pdf
Click the link and the instructions will open in a new window: You can view, print and/or save this file. If you need Adobe Reader to open the file, get it here:
http://get.adobe.com/uk/reader/
Hope this helps. Please rate this solution if you find it helpful. Thanks.
Testimonial: "Excellent and prompt"
Unfortunately, probably not....
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Here
Microwave Oven....
Microwave
Oven
Basic Troubleshooting Tips
heatman101
