Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Dec 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Maytag Neptune MAH5500BWW. The control panel is no longer working for certain selections. I can only wash light loads in hot water. The service repairman did not suggest to fix it as these washers will continue to have other problems. Any suggestions? If I replace it, it will not be another maytag.
SAMUEL ODONOGHUE
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 337 Answers
  • Posted on Dec 21, 2017
SAMUEL ODONOGHUE
Master
Level 3:
Dedicated:
Answers
337
Questions
Helped
91961
Points
1065
Goto ( https://www.maytag.com/ ) click on service then on contact us
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 22, 2008
SOURCE: maytag neptune mah5500bww leaking water
i would check for holes in the boot assy , if so replace boot
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 22, 2009
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Anonymous
  • Posted on May 25, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Anonymous
  • 525 Answers
  • Posted on Jul 17, 2009
SOURCE: My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Anonymous
  • 1606 Answers
  • Posted on Nov 17, 2009
SOURCE: progressively louder on spin
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
1helpful
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Cotton/sturdy button not working on the select fabric
"I have the maytag neptune mah5500bww. the cotton/sturdy button" it has an led read out.
1helpful
Maytag neptune key pad ocassional working
The machine control pad, with the LED lights, is going out. Replace this control pad and all lights should be working normally again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
2helpful
2answers
Mah5500bww
there is probably a Conversion kit for this.You HAVE TO REPLACE BOTH  motor/control board .Im here to help you if need my assistance.
1helpful
2answers
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
