Question about Lite On Computers & Internet
My redcolors in my monitor EC150AT 15 inch old type flat screen from LITEON are to high so my white colors are gone what can I do? I don't have my Floppy disk for test patterns and set up any more, do you have a solution? I do have the manual for panel control but nothing seems to work when I adjust the colors whith user controls off the monitor.
Posted by petervaessen on
5 Related Answers
Anonymous
  • 180 Answers
SOURCE: Samsung 19" monitor control problems
Your logic board need to service.
Posted on Apr 20, 2008
Anonymous
  • 40 Answers
SOURCE: Screen So Bright I Can Barely See Anything...
The auto dimming circuit on the ccfl inverter is out.  Replace the inverter and it should cure your problem.  Seek adult supervision for this repair. Do not try it by yourself.
srich
Posted on May 27, 2008
antiochpc
Kevin Shafer
  • 1314 Answers
Unfortunately the problem is the monitor has gone bad, more specifically and likely is the backlight which is used to light up the monitor. You could fix it by replacing the LCD, but you can get monitors cheaper than a replacement LCD so it wouldn't be very cost effective to do so.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
Anonymous
  • 22 Answers
SOURCE: AOC LM 720 Flat Panel LCD Monitor
try to check the capacitors
Posted on Jan 08, 2009
Anonymous
  • 12 Answers
SOURCE: My 15 inch Dell LCD flat screen monitor has 4 blue
Sorry, but it's kaput. Broken. LCDs were pretty bad a few years ago. A new one will cost a lot less than that one did, and will work a lot longer.
Posted on Oct 01, 2009
Testimonial: "Thanks Stephen, I sure do appreciate the help, I also appreciate the fasst response."
White screen
test your computer with another monitor, if same issue occurs, problem is on video card/cables of your computer, if it runs good on another monitor, old monitor has problem.
Mar 22, 2014 | eMachines 15 inch Monitor
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of [email protected] hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
I have a Cornes 1503T flat screen monitor that is white on the the screen with mutli color vertical lines on the screen /monitor, it is 8 years old, Is it dead or can it be repaired It is used in an...
The picture board on your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 01, 2010 | Cornea CT 1501 (White) 15 in. Flat Panel...
My 15 inch Dell LCD flat screen monitor has 4 blue (cyan) verticle pixel bands about half an inch wide on my screen. The monitor is about 3 or 4 years old. Can you help?
Oct 01, 2009 | Dell 1505FP 15" LCD Monitor
I cant connect a 10 amp noise supressor
you connect pair of rca to you car deck and the other pair to your amp inputs, this just acts like a bridge to filter out noise between deck and amp
Sep 16, 2009 | Car Audio & Video
My HP Pavillion F1503 15 inch flat screen monitor has all different color lines on it when I plug it in and it wont turn on??
Have you tried the monitor on another computer? If it works on another computer but just not this one, the first thing I would check would be the video card drivers. If those are fine, you could have a bad video card.
Jun 08, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Sony Screen Colors
it may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Oct 25, 2008 | Computers & Internet
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
